Navigation & Audio Another AUX installation question
Old May 15, 2020 | 08:41 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
2006 R53 with HK Sound System
I just plugged an AUX cord I sourced into port on the back of the radio. The AUX option came up on the Mode. However, no music is coming out of the speakers from my Android phone. I can hear slight feedback out of the speakers if I remove/reinsert the plug in/out of the phone. I have tried two different AUX cables and they both behave the same. Music is playing on the earbuds from the phone so I know it is there...
Thoughts?
Bad radio??
TIA with any feeback.
Old May 15, 2020 | 10:48 AM
RB-MINI's Avatar
RB-MINI
There should be an adjustment for the aux volume/gain by pressing the music note button on th radio. If it’s set to zero try raising it to see if you get any sound. I usually have the phone volume around 75-80% when setting the level. Also, you might have to check the phone volume every time if you use the earbuds between connections to the radio.
Ideally a fixed line level output is used instead of a variable output like the headphone jack, and the aux gain would be set to match the other source volumes so you don’t get any surprises when switching between sources.
projectslideways
Apr 12, 2020 12:43 PM
Adrien Hupin
Jun 30, 2015 08:43 AM
ckeburgess
Jun 26, 2012 11:28 PM
zack_S_moore
Sep 3, 2009 06:58 PM
Geo-Cooper
Jun 24, 2008 08:25 PM
