R50/53 Replace or just turn this flywheel?
Old Mar 10, 2020 | 08:28 AM
booyah93's Avatar
booyah93
5 speed Midland translation for the 04 R50
Seems like I'll have to go to pick n pull and hope for the best, and if that fails go to mini mania or way motor works. I couldn't find a clutch kit that included the guide tube at my local Auto parts stores. Here's some pictures.
I am having the flywheel turned because it looks fine aside from some heat marks and veins.
Here's the pictures.
Old Mar 10, 2020 | 11:17 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
I'm sure someone in the forum will have a clutch centering tool. He k try an get ahold on modmini.
Old Mar 10, 2020 | 11:54 AM
JAB 67's Avatar
JAB 67
He's looking for a guide tube, not the centering tool.
Old Mar 10, 2020 | 12:03 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Opps my bad.
booyah93's Avatar
booyah93
Funny enough the auto stores keep thinking I'm talking about the centering tool. My guide tube for the throwout bearing is scored in a circular fashion. I'm headed to pick n pull cause they luckily have a couple Coopers in the yard
Old Mar 11, 2020 | 06:42 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
here is the guide tube for the midlands, it comes with the input shaft seal on it too
https://www.waymotorworks.com/5spd-m...uide-tube.html
Old Mar 11, 2020 | 09:26 AM
booyah93's Avatar
booyah93
I appreciate it Way. I can't wait any longer so I'm gonna rotate my tube 120 degrees then put it all back together.
Old Mar 11, 2020 | 09:43 AM
booyah93's Avatar
booyah93
I called my local mini dealer and they just so happened to have the part in stock and for only $36. I didn't bother calling them before because I expected it to be far more expensive.
Old Mar 11, 2020 | 10:24 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Get the new part. Do not try to reuse the old part. It is just not worth the headache.
Old Mar 11, 2020 | 03:23 PM
booyah93's Avatar
booyah93
I'm struggling to get this part off. The rubber seal is like metal . I tried sending you screw through it and it didn't seem to want to grab maybe I should grab a sharper screw?
Old Mar 11, 2020 | 03:47 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Use a wood screew. Do no put the screw into the small holes. Go between the holes an the crank
Old Mar 16, 2020 | 08:22 AM
booyah93's Avatar
booyah93
The
​​​​​​the bottom Arc is a little further in than the top but I can't reset without tearing it up so I'm moving on
OhFiveR52
Mar 12, 2020 05:17 AM
ioannes79
Jan 17, 2019 07:57 AM
sterlingarcher
Jul 3, 2018 12:18 PM
Austin803
Feb 17, 2014 08:53 AM
starionturbo
31
Feb 28, 2013 04:34 AM
