R50/53 No Power Over 17 PSI
Old Mar 3, 2020 | 07:10 PM
m1n1mee98's Avatar
m1n1mee98
So, I just replaced my supercharger pulley with a 15% reduced pulley with a +2% ATI Crank pulley. I got NGK BKR8EIX sparks plugs and a 1360mm serpentine belt to complement these upgrades. I have noticed that I have no power of 17 PSI of boost. Looking at the calculated boost on my Bluetooth OBD-II. This is usually around 4000 RPM. I have a code P0108, which is relating to the MAP sensor. I ordered a new one and installed it today and I am still having this issue. Is my ECU limiting power to protect the engine?
Any help would be appreciated, thank you!
Old Mar 3, 2020 | 09:23 PM
Teabudy's Avatar
Teabudy
I did a search and found this...
https://www.northamericanmotoring.co...ng-solved.html
Let me know how it goes. I’m waiting for all those parts myself. I’ve already had a couple moments of falling flat with my catless headers. I wonder if the issue will arise for me as well.
good luck!
Old Mar 4, 2020 | 02:22 AM
adriancl's Avatar
adriancl
Sorry to ask you have replaced the sensor you need?because R53 have two MAP sensors, you need to replace the right one mounted on Intake manifold.MAP sensor can work up to 26PSI.
Old Mar 4, 2020 | 04:24 AM
m1n1mee98's Avatar
m1n1mee98
I only replaced the MAP sensor on the intake manifold. The one one the thermostat housing looked pretty much brand new when I pulled it out. I do have a P1498 code, which is unmetered air after the compressor. Could that be caused by a vacuum leak?
Old Mar 4, 2020 | 08:44 AM
m1n1mee98's Avatar
m1n1mee98
So, turns out it was an easy and cheap fix. I noticed the vacuum hose on the intake manifold had popped off from the increase in pressure. So I picked up some vacuum fittings and replaced all the ones I could see. I also put a hose clamp on the one that had popped off to make sure it didn't happen again. I am able to rev over 4k, the P1498 code hasn't popped up, and the engine seems to be running much smoother!
moseichuk007
Sep 29, 2020 08:45 AM
Cobrabud
Jun 26, 2013 06:59 AM
hernlui
Jul 30, 2010 10:53 AM
raul
Nov 13, 2007 11:06 AM
AstroBlackBeast
May 19, 2006 01:41 PM
