Drivetrain HELP! Pulley install fail!
Old Jul 23, 2010 | 07:54 PM
hernlui's Avatar
hernlui
Guys today I installed a 15% pulley on my MCS and also a brand new bypass valve. Everything went great except when I drove the car. I actually feel it has LESS pull than with the standard pulley. Brand new belt too and it is not slipping as the A/C is working perfectly and there is a healthy, higher pitch SC whine.
I just don't feel it!
What could have gone wrong??
Old Jul 24, 2010 | 04:24 PM
Burno's Avatar
Burno
Not sure ...Try getting it re-tuned to the new mods you put on...Just guessing here..
Old Jul 24, 2010 | 04:32 PM
Agarwaen's Avatar
Agarwaen
If the BPV were remaining a bit open, I would think you could be losing boost from the constant re-circulation. If the belt is not slipping and you are getting the SC spinning faster (louder, higher pitch) It only makes sense that you are loosing boost somewhere. Do you have a way to check boost PSI? You should be getting like 14-15psi with a 15%pulley. 10-11 PSI is stock. It only makes sense, that if the pulley/belt was installed well and not slipping, that you would be losing power from the only other thing you worked on, the BPV.
Old Jul 24, 2010 | 05:04 PM
hoonpv's Avatar
hoonpv
i would def check boost leak.
specifically the bpv since that's the only area where you've touched.
Old Jul 24, 2010 | 06:46 PM
daflake's Avatar
daflake
Concur.... Boost leak likely at the BPV.
Old Jul 24, 2010 | 09:30 PM
hernlui's Avatar
hernlui
Yeah there was a leak alright. It was late, we were tired...
After driving it for a while and paying close attention, I started to notice a hiss under acceleration.
Looks like when we were installing the IC one of the corners of one of the rubber boots got pinched by the clamp. At first it didn't look like a mayor culprit, but I loosened the clamp, re-positioned the boot, took it out for a test drive and there was a noticeable difference. The hiss is gone too.
Gotta test it tomorrow for a longer period of time so the engine heats up to regular operating temperature.
Thanks guys.
Old Jul 25, 2010 | 12:16 AM
hoonpv's Avatar
hoonpv
those IC couplers are such a pain in the *** to put it back on..
anyways, glad you found the leak. let us know how the car performs tomorrow. pulley does wonders for our cars
Old Jul 25, 2010 | 09:25 PM
hernlui's Avatar
hernlui
Yup, it was the leak in the IC boot.
It's alive! IT'S ALIVE!!
Old Jul 30, 2010 | 10:45 AM
FlipSmini's Avatar
FlipSmini
That's what I'm
Talking about. Another pullied mini. That mod is amazing!
Old Jul 30, 2010 | 10:53 AM
ALTA_Jarid's Avatar
ALTA_Jarid
Mwahahahaaaaaa!!
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
