R50/53 New homelink mirror - Keyless entry doesn't work anymore
Old Feb 8, 2020 | 02:58 PM
Mr_Stop's Avatar
Mr_Stop
I just upgraded my rearview mirror to a preowned mirror with autodim & Homelink. It was supposedly from an 05-06 and should be plug & play with my 2006.
Anyway, I just installed it and my remote key fobs no longer work. I tried to do the reprogramming steps and still nothing. Any suggestions?
Old Feb 9, 2020 | 02:45 AM
adriancl's Avatar
adriancl
If your preowned mirror is from European car , not work because have other frequency for communication.
Old Feb 9, 2020 | 08:09 AM
Mr_Stop's Avatar
Mr_Stop
Thanks for the suggestion. The mirror came from the US, so unless it was originally from elsewhere, it should be the same frequency.
Old Feb 9, 2020 | 08:23 AM
Mr_Stop's Avatar
Mr_Stop
In doing some searching, it appears that the circuit board may to blame:Any other suggestions before I open up and perform surgery?
Old Feb 16, 2020 | 04:38 PM
Mr_Stop's Avatar
Mr_Stop
I opened up the mirror. There wasn't any signs of corrosion on the remote key circuit board. The circuit board was also stamped with 315 Mhz, which I believe is the correct frequency. I went ahead and sprayed electrical contact cleaner on the board, but still no key function.
When I swapped the old mirror back everything functioned correctly after key programming?
I could maybe sway out the circuit board from my old mirror, but they are different in size and connection. The homelink board is larger and has 4 wires going to it. The non-homelink only has three wires.
Suggestions?
Old Feb 18, 2020 | 03:01 PM
gumbedamit's Avatar
gumbedamit
Suggestions?
You are trying to add a feature, (HomeLink) into your car that you did not have before? I'm not certain, but I think that would be something that has to be programmed for your car, different circuit boards and features. As a result of the different circuit board, it's not registering on your ECU/BMC. That's just my thought, I could be completely wrong....
Old Feb 18, 2020 | 04:54 PM
Mr_Stop's Avatar
Mr_Stop
Programming the ECU is certainly a possibility. However, I have read other threads that state it's plug and play. The previous owner said he took it out of his 2005 MCS and it worked fine.
What's weird is that it looks like the Homelink, Autodim and Keyless Entry boards/features are all separate from one another. I'm going to swap the boards out and see what happens...
Old Feb 18, 2020 | 07:32 PM
Mr_Stop's Avatar
Mr_Stop
I put my old board in the new Homelink mirror and the remote door locks now work. However, the Homelink light only flashes when the car is turned on now. I'm guessing the fourth wire to the board is an "always on" power jumper to the homelink mirror.
Old Feb 19, 2020 | 10:44 AM
deepgrey's Avatar
deepgrey
There is no programming required. I did the same swap a couple of years ago.
Old Feb 23, 2020 | 03:58 PM
Mr_Stop's Avatar
Mr_Stop
I just tried the homelink keyless entry board plugged directly into the old connector and still nothing is working. I'm going to assume it's got a bad board.
Old Feb 23, 2020 | 04:44 PM
Mr_Stop's Avatar
Mr_Stop
Researched the P/N and discovered the mirror is from an R56....
Old Feb 29, 2020 | 04:24 PM
Mr_Stop's Avatar
Mr_Stop
Ordered a different mirror from @ALLMAGAutoParts and it worked flawlessly. Totally plug and play with a little dancing to get the keys and garage remotes programmed.
Old Mar 2, 2020 | 09:33 AM
ALLMAGAutoParts's Avatar
ALLMAGAutoParts
That's what I like to hear!! Cheers!
Old Mar 2, 2020 | 11:00 AM
audihere's Avatar
audihere
I had a similar problem when upgrading my mirror. Posted a little about it here.
https://www.northamericanmotoring.co...ml#post4413523
zman70
Apr 14, 2026 06:56 AM
fridayxiii
Mar 24, 2022 04:41 PM
Joe Kewl
Jan 8, 2017 08:42 PM
rhasenohrl
Oct 12, 2009 10:05 AM
jascooper
Oct 15, 2007 10:09 AM
