R57 What part is this?? Help!
Old Jan 4, 2020 | 02:59 PM
BlueMiniac's Avatar
BlueMiniac
I had to duct tape it on so it’ll stay. But the brackets or clips are clearly broken. Need new piece. What is it??
Old Jan 5, 2020 | 02:38 AM
MiniToBe's Avatar
MiniToBe
That's the noise maker. Some cars specially with N18 engines don't have it.
Old Jan 5, 2020 | 04:26 PM
BlueMiniac's Avatar
BlueMiniac
Noise maker? Is it needed to function and drive?
Old Jan 5, 2020 | 07:01 PM
MiniToBe's Avatar
MiniToBe
It runs back to the air pipe going to the throttle body. If you remove the whole thing, you'll have a major leak. You coul cat it or upgrade that whole concoction
Old Jan 6, 2020 | 07:40 AM
All the info here: https://www.northamericanmotoring.co...anifold-2.html
Like MINI to be said its just s noise maker that reverberates sound from the intake into the cowl.
Old Jan 6, 2020 | 01:06 PM
BlueMiniac's Avatar
BlueMiniac
Thanks to all who helped!! This was great! I'll get the part.
Old Jan 6, 2020 | 01:50 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We actually remove them as you will find you get better throttle response and just a hair more power without it as it causes you to loose up to a half pound of boost to activate the diaphram in it.
We have a pipe that directly replaces the entire unit.
https://www.waymotorworks.com/wmw-no...5-r56-r57.html
redlinealley
Dec 18, 2018 07:23 PM
WayMotorWorks
Jun 14, 2018 06:50 PM
Edgpr
Dec 13, 2013 10:55 AM
MCS_2008
Jan 5, 2013 11:41 PM
MrPinkFloyd
Mar 8, 2009 07:33 AM
