Can I put OEM Xenon Lights on My Halogen Equipped R53?
Old Aug 11, 2019 | 08:32 PM
Marc08EX's Avatar
Marc08EX
My 06 R53 unfortunately has the halogen headlights. I really like the OEM 05-06 Xenon headlights and was wondering if swapping them out would be a plug and play ordeal?
Thanks!
Old Aug 12, 2019 | 11:26 AM
Lots of work and you dont have the level sensors. The best thing would be to do this if you want to OEM style look:
https://www.northamericanmotoring.co...installed.html
Old Aug 12, 2019 | 11:39 AM
Marc08EX's Avatar
Marc08EX
Thanks for the reply ECS!
Oh it's not just a plug and play deal? =( Are there any DIY articles? I tried searching but didn't find any...
Old Aug 12, 2019 | 12:00 PM
No, you have headlight washers and other things that did not come factory with halogen, much easier to do the DIY above.
Factory DIY: https://www.northamericanmotoring.co...on-lights.html
OLD original kit linked in thread with install PDF (NLA kit) : https://www.northamericanmotoring.co...o-halogen.html
Other conversions: https://www.northamericanmotoring.co...sion-help.html
Old Aug 12, 2019 | 09:09 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you actually can as we have done it several times on R53s including my own personal GP as it didn't come with Xenons. But you have to recode the car to make them work.
No need to worry about the washers as they don't do anything but splash water all over your hood.
For the level sensors we just adjusted the lights properly and slightly down and have no issues.
Old Nov 16, 2020 | 07:54 PM
RhinoEngler's Avatar
RhinoEngler
Way motor works. I have a r53 wrecked it front end...I bought a 2006 hood and it as the xenon light can you help on what the process is to make them work?
Old Nov 16, 2020 | 07:56 PM
RhinoEngler
I have a r53 and got a new hood that has the xenon in them can you help..how and what do I need to do? Thanks
Old Nov 16, 2020 | 08:21 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Sorry to thread hump BUT can you go the other way..theres no aftermarket xenon lights and there's a sweet set of halogens on sale . Can I revert back to them ?
https://www.ebay.com/itm/For-2002-20....m46890.l49292
Old Nov 19, 2020 | 10:18 AM
You could go back to aftermarket projectors. Just have to disconnect the washer system and the plugs past the ballast are the same as the halogen/Xenon. https://www.ecstuning.com/Mini-2005-...s/US_Spec_Set/
Old Nov 20, 2020 | 07:00 PM
MiniManAdam
Community Builder
Originally Posted by ecstuning
you could go back to aftermarket projectors. Just have to disconnect the washer system and the plugs past the ballast are the same as the halogen/xenon. https://www.ecstuning.com/mini-2005-...s/us_spec_set/
o sweet !
cause any dummy lights or codes ?
Old Nov 23, 2020 | 10:44 AM
Nope, its a simple system. This is before the systems require canbus and the LKM was more advanced.
Old Nov 23, 2020 | 04:41 PM
Eurothrasher's Avatar
Eurothrasher
Thanks!
IF your MINI came factory with Xenon, one can switch to halogen....but not visa-versa....sorry. Between parts, labor and coding you may as just as well go out and purchase a R53 with Xenon.
Old Nov 24, 2020 | 10:28 AM
MiniManAdam
Community Builder
o wait until I get my new headlights and sell off my xenon units and ballasts for cheap.. can't inpa fix the coding ??
Old Nov 24, 2020 | 10:34 AM
Eurothrasher
Between parts, labor and coding you may as just as well go out and purchase a R53 with Xenon. ( would be cheaper )
Daniel Ramos
Feb 28, 2019 05:37 PM
minicooperlover22
May 3, 2018 08:39 AM
dyeLucky
May 25, 2016 10:37 AM
Zimm
Electrical
Apr 22, 2015 03:08 PM
crankshaft
Apr 27, 2014 10:08 AM
