P0303 Has Me STUMPED!
Old Jul 30, 2019 | 10:32 AM
trwtestengineer1's Avatar
trwtestengineer1
Have 2007 R56 N12 (89,000 mi) throwing P0303 cyl # 3 misfire. Now, the vehicle runs great and easy to detect a misfire in a 4 banger, not the case, Performs quire well cold or hot.
I have:
Replaced plugs (due anyway)
swapped coil packs
Fuel pressure on the rail is good
Removed and tested all injectors, just fine
Compression, a little high but consistent @ 220-225 psi across all, wide open throttle, fuel pump disabled
Traced all injector and coil wiring, good.
From the somewhat high compression, looking at the piston crowns seems some carbon buildup so I tried the Seafoam thing, without any difference (compression OR performance)
no oil leaks from the plug seals, so replaced anyway to be in "good form"
so..... clearing the code results in about 10-15 miles before re-occurrence of the P0303, hot or cold start, easy or "spirited" driving.
Just stumped, since the damn thing runs so well and has been for the last 3-4K miles with this issue
Anyone seen this before?? thx.
Old Jul 30, 2019 | 11:50 AM
mkov608's Avatar
mkov608
Yes, take the car to an indy shop and have them put it on the scope. My problem was an intermittent injector that showed up on the scope. Replaced injector (just the #2 cylinder) and the problem disappeared.
Old Jul 30, 2019 | 11:57 AM
trwtestengineer1
Did you have a P0302?? thx.
Old Jul 30, 2019 | 11:59 AM
mkov608's Avatar
mkov608
Yes.
Old Jul 30, 2019 | 12:03 PM
trwtestengineer1
Yes I understand the DTc's..... P0301, cyl#1 Misfire, P0302, cyl#2 misfire.... etc...
Was Kindly asking what was YOUR DTC code? thx.
Old Jul 30, 2019 | 12:04 PM
gumbedamit's Avatar
gumbedamit
He does have a good idea, move the coil and injector to another cylinder and see if the code follows...
Old Jul 30, 2019 | 12:06 PM
trwtestengineer1
Nope.... coil and injector already swapped, no change still P0303
Old Jul 30, 2019 | 12:08 PM
gumbedamit's Avatar
gumbedamit
What do I know, just have a R53...
fitternickel
Jan 13, 2018 11:56 AM
4GAZM
Nov 17, 2008 08:56 PM
MacGuruTX
Apr 21, 2008 04:10 PM
Skin_Mechanic
Sep 22, 2004 10:43 PM
jakestner
28
Jul 2, 2004 05:07 AM
