2004 R50 P1611 and P1613
Old Jul 25, 2019 | 09:00 AM
Ken Hirako's Avatar
Ken Hirako
Hello,
This is my first time posting on these forum.
I just need help fixing my 2004 Mini Cooper R50.
So I pulled out a P1611 and P1613 out of my Mini.
What happens is that during extremely hot weather, like above 100 degrees, my Mini will start misfiring during idle and at lower speeds.
The battery, spark plugs, compressor, alternator have been recently changed.
I even tried clearing all adaptations with INPA the other day.
I would appreciate some help please.
Could it be that the connectors are dirty? I saw somewhere that I should check the large connector connected to the transmission but I don't know where it is and how to access it.
I also saw in another thread that the circuit board under the center console may be worth checking as well.
thank you
Andrew
Old Jul 25, 2019 | 10:57 AM
HaltCatchFire's Avatar
HaltCatchFire
These are ASC/DSC and Gearbox Interface Unit (GIU) communication errors. Something on the CAN bus is wigging out - very often this is the CVT circuit board or steering angle sensor. Do you have a CVT?
Old Jul 25, 2019 | 11:10 AM
Ken Hirako's Avatar
Ken Hirako
yes it is a CVT. thank you for your help
Old Jul 25, 2019 | 11:38 AM
Ken Hirako's Avatar
Ken Hirako
Ok I think I can find the GIU (under the steering wheel panel) and the steering angle sensor and see if there are connectors dirty or not connect well.
I was looking at the link below and thought that thismay apply to me as well.
https://www.northamericanmotoring.co...sible-fix.html
In the link it said that this board is below the center console but do you know what this board is?
Old Jul 25, 2019 | 12:47 PM
HaltCatchFire
I don't know much about the R50s, but I believe it's under or near the steering column.
You can try putting a DMM on the CAN bus and measure the resistance with the car off. You should see 60 ohm between the two data lines and several megaohm to GND on each. This will give you a quick check on the transceivers.
numbersix
36
Feb 9, 2025 11:58 AM
Rahmanz
Oct 17, 2023 08:37 AM
SpiderX
Feb 21, 2019 01:11 PM
JPP
Jan 18, 2016 11:50 AM
2003minicooper
May 18, 2013 07:08 AM
