Help with limp mode
Old May 28, 2019 | 09:55 PM
aitch1's Avatar
aitch1
Help with limp mode
I have changed the spark plugs I have changed the oil I have changed the Vanos Solenoid and I have change the camshaft sensors. If my car is cold when I started it goes into limp mode until I turn off the code but if it's hot no limp mode I need help what else should I try
Old May 29, 2019 | 09:56 AM
MrGrumpy's Avatar
MrGrumpy
What codes are you getting? What year and model?
Old May 29, 2019 | 10:17 AM
aitch1's Avatar
aitch1
I have a 2011 mini cooper S.
Now I get a code p15df
Old May 29, 2019 | 10:58 AM
MrGrumpy's Avatar
MrGrumpy
From what I can find, it looks like that is a code for cold start fuel pressure. There is a good chance that your HPFP (high pressure fuel pump) is starting to go, it’s a known issue on these. Depending on your mileage, you may very well be covered by a warranty extension from MINIUSA for it. If so, a huge plus! They have extended it out to 100,000 or 120,000 miles.
Go on the website for Miniusa and there is a section where you can enter your VIN and it will tell you which warranty extensions you are covered for.
ahmedalsurmi
Sep 25, 2023 04:49 AM
Jonny Crisp
Mar 31, 2017 10:57 AM
teleautomata
Dec 18, 2012 05:21 PM
Eriko
Mar 29, 2007 03:50 PM
