Drivetrain Losin it .. Need belt size help !
Old May 16, 2019 | 08:10 AM
frankiev's Avatar
frankiev
After shreding two belts I replaced the tensioner with one from amazon . I have a 15% sc pulley and a 2% crank pulley . I ordered a stock belt which I was told would fit . Unfortunatly theres no way thats going to fit . I had the tensioner at the second stop , basically all the way back. There was no chance in hell of getting that belt on . I think it was gates 06535. . Would the next larger size fit or should i go two sizes ?? I believe 06539 is the next one although I was told the JCW belt might fit . Any recommendations appreciated
Old May 16, 2019 | 08:46 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
I have the 2% WMW crank pulley, but stock 11% JCW s/c pulley --- I run a ContiTech 1374 and all is well.
The 1374 indicates mm length.
ECS recommends a 1364mm belt for 2%+16%
https://www.ecstuning.com/b-gates-pa...9/k060535~gat/
Hopefully others will weigh in with actual experience.
Old May 16, 2019 | 09:34 AM
frankiev's Avatar
frankiev
I appreciate the response but this adds to the confusion . The gates k06535 is 1379mm and it wont fit , too small ,so I don think 1374mm would .
Old May 16, 2019 | 12:20 PM
Oldboy Speedwell
Quite confusing indeed ---
--- although the Gates does indicate 1379mm, that is for the OC = outside circumference,
so according to the label we'd say it's 1364mm because it states 6PK1364.
Old May 16, 2019 | 01:26 PM
frankiev's Avatar
frankiev
Thank you for that . I ordered a K060539 which is the next largest size . Will be here tomorrow and I post the resul
Old May 16, 2019 | 01:46 PM
Oldboy Speedwell
Good deal.
That one is 1370mm so it should do the trick.
Cheers!
Old May 16, 2019 | 01:54 PM
Altecfenix's Avatar
Altecfenix
That's so strange, the stock belt should fit perfectly. 060535 is not the stock belt though if that's the one you were using.
Old May 16, 2019 | 01:58 PM
frankiev's Avatar
frankiev
According to the ATA chart I found it said the stock one was the 060535. What is the stock size ??
Old May 16, 2019 | 02:01 PM
Altecfenix's Avatar
Altecfenix
You just ordered it lol. 539 is the stock belt if memory serves correct.
Had the 2% OD and 15% SC on my R53 and ran 539.
Old May 17, 2019 | 06:08 AM
Oldboy Speedwell
K060535 and K060539 are not stock --- they're both much smaller.
6PK1364 and 6PK1370 is so much easier to decipher for me as I never have like fractional measurements, and especially when it's in like 10ths of an inch!
K060535 = 1364mm
K060539 = 1370mm
Stock MCS size is 1388mm.
Old May 17, 2019 | 08:13 AM
Altecfenix's Avatar
Altecfenix
K060535 = 1364mm
K060539 = 1370mm
Well hell, I've been misinformed if that's the case.
Will adjust my notes! Thanks!
Old May 17, 2019 | 09:34 AM
frankiev's Avatar
frankiev
OMG ...its a good thing I love this car ..Always seems to be a pia ..lol
Old May 21, 2019 | 07:35 AM
frankiev's Avatar
frankiev
I finally installed the 60539 and its tight but fits . I dont like the fact that the tensioner is showing the entire hole and its close to showing the second hole so Im going to order the stock 1388mm belt . Currently theres a old belt Im using and its worn but looks like contitech6pk1388 which is a heavier belt than the Gates so thats what Im going to get . Thanks to everyone that helped
Old May 22, 2019 | 12:55 PM
twokbolt's Avatar
twokbolt
I believe the 60539 belt is for the JCW cars with a smaller supercharger pulley. At least that is the part number I have for my car which I need to order. I believe 60547 is for non-JCW cars which should be slightly longer.
Nelson Costa
Jul 10, 2017 10:55 PM
HFDZDN
Apr 3, 2013 09:00 PM
HFDZDN
Feb 26, 2013 03:55 PM
NC TRACKRAT
Aug 15, 2009 05:15 PM
sndwave
May 13, 2007 07:08 PM
