Drivetrain where to measure pulley at
Old May 23, 2019 | 06:25 AM
brusk's Avatar
brusk
I have an 05 JCW but the engine was swapped with an 06 S. Looks like they kept all the important stuff but I'm not positive about the supercharger. I found the dimesions of like 2.2 and 2.58 or something but I didn't see mention of where that measure was coming from. Is that at the rib or at the front lip?
Old May 23, 2019 | 08:58 AM
BlwnAway's Avatar
BlwnAway
The measurement should be O.D. In mm from the top of the ribs.
But I don't remember the actual diameters of stock -vs- JCW.
Old May 23, 2019 | 09:06 AM
brusk's Avatar
brusk
Thanks, that doesn't make it exactly easy. Screw it I'll just replace it with a 15% that way I know it's what I want it to be.
Old May 23, 2019 | 03:52 PM
cooper48's Avatar
cooper48
F.Y.I. I believe the stock JCW SC pulley is an 11% overdrive (someone correct me if I'm wrong) so moving to a 15% will get you where you want to go.
Old May 23, 2019 | 04:21 PM
A383Wing's Avatar
A383Wing
Yes....the stock JCW supercharger pulley is around 11%........I had all the diameter measurements written down here somewhere.....but I can't find them right now....
To the OP....if you are going to remove your supercharger pulley, it will take a different puller depending on if your pulley is a JCW version or just an S version....so you will need to determine which one you actually have.....I have a factory JCW and a factory S if you want me to try and measure the pulleys for you
Bryan
Old May 23, 2019 | 04:31 PM
Altecfenix's Avatar
Altecfenix
If you're having a hard time finding a puller, here's a link to ours: https://www.cravenspeed.com/quick-pu...-supercharger/
Old May 23, 2019 | 08:42 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You could just post a pic and we'll tell you all about it.
Here is what a JCW pulley looks like
Old May 24, 2019 | 07:07 AM
brusk's Avatar
brusk
Here was the best pic I could get with my phone.
Old May 24, 2019 | 12:18 PM
A383Wing's Avatar
A383Wing
Looks exactly like my stock '06 JCW pulley on my car
Bryan
Old May 24, 2019 | 12:23 PM
brusk's Avatar
brusk
I was only getting 12-12.5 lb of boost. To make sure everything is how I want I ordered the 15% pulley, 2% crank, DT BPV and a few other maintenance items. should run a little better then.
Jeremy1026
GP Talk (2006)
Aug 13, 2007 05:45 AM
Minifiend
Suspension
11
Jun 5, 2007 05:45 PM
Super_MINI
Dec 15, 2005 08:25 AM
mcs22004
Jan 6, 2004 12:50 PM
Yucca Patrol
Nov 25, 2002 12:29 PM
