Electrical My various projects - Auto Up module, Shift Light, Atoto A6 retrofit
Old Mar 31, 2019 | 05:31 PM
socalva's Avatar
socalva
Just wanted to show some of the projects I've been working on for the last year - my auto up module, CAN BUS shift light, and Atoto A6 headunit retrofit into the center cluster. If there's interest, I can show some pictures on how I got the headunit to fit.
Old Mar 31, 2019 | 06:50 PM
co0p3r's Avatar
co0p3r
Interested in the Can based shift light - post more on that.
Old Mar 31, 2019 | 07:25 PM
Oldboy Speedwell's Avatar
Oldboy Speedwell
+1
I like the design of the shift light and would love more info.
Old Mar 31, 2019 | 08:00 PM
socalva's Avatar
socalva
I’ll take another video showing the different features. It’s based on Chippernut’s shift light code that I modified to accept can bus signals using an MCP2515. I’ve decoded almost all of the cluster based signals for the single and dual clusters. So the shift light auto dims with the headlight, and can display CEL, temp, odo, etc.. I’m working on integrating them into a touch screen race dashboard based on a Nextion screen. That was I can get rid of the steering wheel cluster. Here’s a few more videos of it in action
Demo mode
Using it at Chuckwalla raceway
Old Mar 31, 2019 | 08:08 PM
co0p3r's Avatar
co0p3r
OK I am interested in 2 of the shift lights, one for a 2006 MCSa JCW with Chrono and another for a 2006 MCS Manual non-Chrono.
I plan on switching the Manual car to a LinkECU standalone I wonder if it will still work with that ECU
I would take one of the auto up circuits also, I have the Ian Cull v7 in both car now, the MCSa works perfect but the Manual car the Auto Fogs is "flaky the a cresant" the track mode on it and the windows work fine but it turns the fogs on and off.
BTW before someone says anything about 'you dont shift a auto trans' the car has paddle shifts, that can be used in the sport mode and the other reason is its cool
c0op3r
Old Apr 1, 2019 | 03:57 AM
Oldboy Speedwell
Is the shift light still in the R&D phase?
I really like the auto-dim feature, that's a very nice touch.
Do you happen to have a ballpark figure for what one would cost?
Thanks.
Old Apr 1, 2019 | 11:37 AM
socalva's Avatar
socalva
The shift light is still being developed. The coding is pretty much done for now, but I need to finalize the circuit board and update the 3D design for the case. You can see in the video that the LCD screen is just attached to the bottom of the case and the LED strip needs to be fully enclosed. I'm going to keep that overall design (screen bottom center, LED strip above) what you can't see is the rotary **** used for changing settings like brightness, segment colors, shift point, dimming level, etc.. I also use this to capture raw canbus dumps, so another cool use there. I've been testing it daily since December and it's awesome to use at the track and street. I was hoping to have it completed by now but work's been crazier than usual lately. Not sure what I would sell them for yet, I'll have to see what all of the parts run and assembly time when it's finalized.
Old May 5, 2019 | 01:40 PM
Mini_Crazy's Avatar
Mini_Crazy
I am also interested in the shift light. 2005 Manual w/Chrono.
Looks good!
As Oldboy said, the auto-dim feathre is a particularly useful idea for after dark.
Old Oct 2, 2019 | 10:47 AM
socalva's Avatar
socalva
Here's an update to the shift light.. re-designed to use a touch screen and display more canbus data. Here it is using 8 LED's but it can support up to 30. I'll most likely have either 10 or 16 in the finished design. I'm pretty happy with how this is turning out.. my goal is to get rid of the little cluster. I'm working on adding a wireless gear position indicator next.
Old Oct 8, 2019 | 11:21 PM
kensic's Avatar
kensic
did you use inpa to code the windows one touch operations?
by the way, where in so cal are you located?
Old Oct 9, 2019 | 09:59 AM
socalva's Avatar
socalva
That's an auto-up module I made.. you can buy it from Way if you contact him. Although depending on your model year, you can use INPA to code single up/down as well. The module does dual auto up/down and other things like disable DSC on startup, auto fog lights, etc.. I'm in the LA area
Old Oct 9, 2019 | 12:00 PM
kensic's Avatar
kensic
yea ultimately i'm just looking to get one touch up windows. and open / close windows with key, just those factory settings. and eventually activate cruise control (i need to install my retrofit kit.) . would you able to help me with those? im in the OC, ofcourse i would pay you for your time.
Old Oct 13, 2019 | 08:14 AM
Husky44's Avatar
Husky44
https://youtu.be/EOlhoBXAn9w
Did you ever do a post or video on the head unit refit?
I'm still looking for options to repurpose the dash space consumed by my factory nav.
Old Jan 29, 2020 | 01:37 PM
mountainhorse's Avatar
mountainhorse
Bump...this module is great.... and Socalva is a pretty clever guy !!!
Old Jan 29, 2020 | 02:46 PM
cooper48's Avatar
cooper48
Socalva, what would be really super great is if you developed the shift light as a dashtop mount that projects a heads-up display on the windshield. The last thing you want to do entering a corner is look down at the shift light. By the way, anyone who's interested, I bought Socalva's R53 auto-up window switch when it was under development (been in my car for around a year) and it works perfectly.
Old Jan 29, 2020 | 05:44 PM
socalva's Avatar
socalva
Thanks! I appreciate it. I've thought about doing something like that, but I'm still perfecting the features/interface before really exploring it - I've even thought about doing a basic version that integrates directly into the steering wheel. As for the current status, I've recently upgraded to a 4.3" touch screen, designed a 3d printed case for it, and designed a wireless gear position indicator (it uses an nrf24l01 module for 2-way communication between the screen and gear sensor). Here's a quick drive video I filmed today..
Old Jan 29, 2020 | 05:54 PM
mountainhorse
Boy....Lovin my Module...Would be over the moon to get my hands on one of those displays!!
Need any Paying Beta Testers??
Old Jan 29, 2020 | 06:26 PM
mountainhorse
The Instruments in the new Konigsegg Jesko... steering wheel mounted... Watched the numerous vids... seems kind of awkward to me..
Old Jan 30, 2020 | 09:42 AM
socalva's Avatar
socalva
Yeah, just preference like floating vs fixed paddle shifters. I like the way the cluster is currently in a fixed position though. Hopefully I can take it to the track soon and test it out. I forgot to mention that the cluster also does 0-60 timing that works pretty well since it's reading real-time speed data from the ECU, it also tracks stuff like highest rpm/speed reached, and drive time. I don't think it's ready for testing yet, not with the wireless gear indicator anyways. I still need to design a baseplate for the shifter housing so the gear sensor board is easy to install. As a stand-alone unit it works pretty well though.. if people are interested in it without the gear sensor, it might be ready for that. I've got a lot of ideas but limited time to work on it.. I ordered a GPS module and SD card writer so I can use this as a mobile canbus data logger, and track timer. I also ordered a 680 nit screen so it'll be 3x as bright than it is now.
Old Jan 30, 2020 | 01:06 PM
cooper48's Avatar
cooper48
Clever stuff. Nice work.
Old Feb 4, 2020 | 06:20 AM
Derek86's Avatar
Derek86
I'll just jump in to say I've been running one of Socalva's auto up/DSC/etc. modules and I love it. Not turning off the traction control every time I get in the car is fantastic. It's like a real car again!
Old Apr 4, 2021 | 12:07 AM
mountainhorse
Bump... for one well executed design... The window up module with other features... GREAT stuff...
Cheers to a good year of Motoring !!
Oldboy Speedwell
11
Jun 9, 2021 12:13 PM
mini_macky
Electrical
Sep 5, 2007 08:49 AM
SSMini
Nov 11, 2005 01:13 PM
SSMini
Oct 11, 2003 11:07 AM
