No Speedometer... is it the ABS Sensor?
Old Mar 24, 2019 | 07:21 PM
monkeymike's Avatar
monkeymike
Which ABS / Speed sensor controls the speedo?
I replaced my rear hubs and ABS sensors this afternoon. I tried to get working on the fronts, but ran out of time (and patience). When everything was all back together I went for a drive, and I get the Brake light, ABS light, and low tire pressure light. Also, no speedometer readout.
Note, when I was starting on the left front, I did blast the axle nut with a torch for about 10 seconds to loosen the corrosion. Not sure if I heated up the ABS sensor indirectly.
Did I kill the front ABS sensor? Are one of the rears the cause of the issue????
Need some help here. Gotta figure out which one to fix tomorrow.
Thanks,
~mike
Old Mar 25, 2019 | 02:16 PM
A383Wing's Avatar
A383Wing
If I'm not mistaken, the speedo is driven off one of the rear wheels, not the fronts as you would think.....I just don't know which one of the rear wheels it is......
I have an '04 & an '06.......I would like to know which one also, just for future reference
Bryan
MrMicL
Dec 22, 2023 04:39 PM
celticfc
Aug 20, 2015 01:54 PM
MCS02
Oct 30, 2011 06:59 PM
hosmer
Aug 4, 2007 12:53 PM
haulinS
Aug 14, 2006 01:55 PM
