Can’t remove intake manifold 2010 base
Old Oct 22, 2018 | 03:51 PM
Tao's Avatar
Tao
Hello everyone,
I have a 2010 mini and I’ve tried to remove the intake manifold without any success I removed 5 nuts on the intake plus one other on the rear,but the intake is kind of stuck impossible to move.
did someone have the solution for this ?
thank you.
Old Oct 22, 2018 | 04:22 PM
Tgriffithjr's Avatar
Tgriffithjr
Provided that it is not attached to anything else you have to gently pry them off sometimes. But be sure you have disconnected everything.
Old Oct 22, 2018 | 05:08 PM
Tao's Avatar
Tao
Old Oct 22, 2018 | 05:42 PM
Tgriffithjr
Here is a link to https://www.pelicanparts.com/techart...eplacement.htm removal instructions. Probably faster for you to look through this than to go through several replies to find out what you have done so far.
Old Oct 22, 2018 | 06:14 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Originally Posted by Tgriffithjr
Here is a link to removal instructions. Probably faster for you to look through this than to go through several replies to find out what you have done so far.
Might also help to ask question in the correct (R56?) forum for your 2010 MINI...
This is the 1st-Gen R50/R52/R53 forum (2002-2008).
Old Oct 22, 2018 | 07:28 PM
Tao's Avatar
Tao
It was the one showed in the image not easy to get but with some perseverance i got it from the rear using an extension.
i took some pictures but it seems like the gaskets needed to be changed.
actually the engine overheated and I bought it to a mechanic who told me that the engine was probably dead and proposed to buy the car. I refused and asked him to change the defective parts ,he changed the water pump and pipe coolant but didn’t changed the thermostat housing and obviously the car was overheating after 10 min of use .I took the car home and done some research on internet and figured out that I need the check the thermostat housing (it melted).
He didn’t done the pressure test to check if the head gasket was ok or not so I will put the new thermostat housing change the valve cover and see if I will have a good pressure test.
Old Mar 27, 2019 | 12:04 AM
ioannis boulougras's Avatar
ioannis boulougras
hi I have r56 non s 2008 same like you I want to remove the manifold as well...is it the red one that I have to remove? is it 10mm 13mm? I don't have a Jack can I reach it from the rear of the manifold? thank you in advance.
Originally Posted by Tao
sddiver619
Sep 5, 2018 07:49 PM
R56devotion
Sep 25, 2017 01:18 PM
jkjrb
Apr 26, 2015 11:35 AM
fixman2k
Mar 11, 2011 11:41 AM
lamia
Want to Buy - All Other Items (archive)
12
Jul 20, 2008 07:29 PM
