Navigation & Audio Double-Din install plus EXTRAS!
Old Jan 19, 2019 | 09:35 PM
fd3toe46's Avatar
fd3toe46
So I wanted a double-din and after doing a bunch of research without much info I just dove into it. I realized soon that it's best to replace the aging/ugly oem navigation too so I went with a Droid Maxx2 I had laying around. Here is the result!
Old Jan 21, 2019 | 10:42 AM
Soul Coughing's Avatar
Soul Coughing
Bravo! Looks great. Did you have any issues removing the screen? Any codes etc.??
Old Jan 21, 2019 | 10:59 AM
fd3toe46's Avatar
fd3toe46
No issues removing screen at all...it's all 1 unit. No codes that I can see or scanned with a obdii reader.
Old Jan 21, 2019 | 03:45 PM
Husky44's Avatar
Husky44
Looks great! Where's the write-up? How did you do this? Did you drop the toggles and HVAC control down to the very bottom of the stack to make room?
Details on the device you used to replace the NAV screen?
Old Jan 23, 2019 | 07:40 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
There are a few of these double DIN installs in NAM. Few has posted the installation photos except the final product and only not too closeup shots. Like cosmetic surgery it is best not to poke your nose too close during the operation. A bit of hacking and courageous cutting is required. If your are skilled and resourceful the result can be better than buying one of those fancy single DIN double DIN display unit. If you are a bad hack, the result can be a loosely mounted mess that is the center console.
Old Jan 23, 2019 | 12:52 PM
fd3toe46's Avatar
fd3toe46
Here's a little "Tip"...no matter what you do you will have to hack at least 1 of the leg on the HVAC gear thing. I've read some hacked off 2 legs (which imo would make that thing unstable). I only hacked of 1 leg and modified the back of my radio...this trick probably saved a bit more hacking to the HVAC that I would otherwise have to do. And Of course I covered up the electronics.
Old Feb 19, 2019 | 08:26 AM
beachblanket's Avatar
beachblanket
Have you had any problems with the mobile phone overheating? I did with my install.
Old Feb 19, 2019 | 09:18 AM
fd3toe46's Avatar
fd3toe46
Have not experience that..I have an app that put the phone to sleep when power is off and turns phone on. Apparently that app is no longer available on the Play store?
Old Feb 19, 2019 | 09:22 AM
beachblanket
yes llama thats the one i used. As soon as ignition off phone sleep mode...ingition on phone on...
My problem started in the summer last year, phone gave a warning about temperature and sometimes shutdown on long journeys... I may install a small pc fan behind it to take away some of the heat.
Works grewat though with a bluetooth obd and Torque pro...at least you know what the temperature is doing!!!
Old Feb 19, 2019 | 09:23 AM
beachblanket
https://www.northamericanmotoring.co...m-sat-nav.html
my old install....I kept the complete boost radio and bought a bluetooth unit that plugged into the rear
Old Feb 19, 2019 | 09:28 AM
fd3toe46's Avatar
fd3toe46
Yeah...I haven't experience overheating...I don't see why it would unless there's some cpu intensive app running? Torque doesn't seem that bad but then I've only driven the car to work and trips less than an hour.
Old Feb 19, 2019 | 09:49 AM
beachblanket
Great install by the way looks really good
Old Feb 19, 2019 | 10:36 AM
fd3toe46's Avatar
fd3toe46
Thanks...it was your thread that inspired me to do mine!
Old Feb 19, 2019 | 10:57 AM
beachblanket
C O O L I O 😀😀😀
Freshfitz
239
Jun 13, 2020 07:17 AM
matts
29
Nov 10, 2018 07:23 AM
prophetx2
Southern California
Apr 20, 2009 06:00 PM
CustomAV
Mar 27, 2006 09:28 PM
