17x7.5 45mm Offset Fit With H-Sports?
Old Nov 22, 2004 | 09:54 AM
JCampos's Avatar
JCampos
I am interested in these wheels:
http://www.rotawheels.com/subzero.htm
Do you think they will fit? If so would I need to change out my tires with them? Ive got the 205 45 17 Kumho tires on right now.
Old Nov 22, 2004 | 10:09 AM
MartyR's Avatar
MartyR
Should fit fine, no problems. You plan on running 205s or 215s?
Marty
Old Nov 22, 2004 | 10:10 AM
JCampos's Avatar
JCampos
205s til I run em down then go to 215s
Old Nov 22, 2004 | 11:58 AM
onasled's Avatar
onasled
205s will be OK, but you will rub with the 215s most likely, I do.
Old Nov 22, 2004 | 12:00 PM
JCampos's Avatar
JCampos
Ya.... sfjames told me that the guy he talked to at the shop said that the 17/7.5 wheels would fit the same way his car does with 17/7 and 15mm spacers. It ALMOST rubs with his M7 springs so I figured that if I had 215s they would rub.
Thanks for the input. Appreciated
Old Nov 22, 2004 | 04:48 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
With H-sport springs and 17x7.5 rims with +45mm offset you will do better (no rubbing_ with stock 205/45-17 tires. Once you change to 215/45-17 expect a little rubbing on the rear back out wheel wells when driving hard/cornering or with a full load of four people.
Nothing major and doesn't usually requite trimming but some rubbing which you can hear or feel as scraped up plastic on the inner wheel well areas facing the tire's outer edge.
Usually you don't need spacers for this offset. Otherwise the rims are fine, just wider than stock.
Old Nov 22, 2004 | 04:49 PM
JCampos's Avatar
JCampos
Maybe take a dremel to the inside of the wheel well?
Old Nov 22, 2004 | 05:07 PM
Ryephile's Avatar
Ryephile
no, you won't rub enough to warrant the Dremel tool with the 215's
Enjoy
Old Nov 22, 2004 | 05:27 PM
JCampos's Avatar
JCampos
Old Nov 22, 2004 | 06:15 PM
onasled's Avatar
onasled
Wait a minute.....
I run the Kosei 17x7.7 with 215/45 and I rub pretty bad. I have actually rubbed a good size hole through the driver side rear well in the first 200 miles of driving. No damage to the tire at all but I do have to peel of the melted plastic from it.
Maybe Minis are that different that some will and some won't. I am using the H-sports also.
Old Nov 22, 2004 | 06:17 PM
JCampos's Avatar
JCampos
Yea, but youre wheel is also almost a quarter inch wider than mine would be.
Old Nov 22, 2004 | 07:09 PM
kyriian's Avatar
kyriian
Originally Posted by onasled
Wait a minute.....
what tire you got.. tires with very square shoulders increase chances with rubbing as well
Old Nov 22, 2004 | 07:12 PM
JCampos's Avatar
JCampos
Im running the Kumho Ecsta Supra 712s.... dunno bout him
Old Nov 23, 2004 | 04:44 AM
onasled's Avatar
onasled
I typoed!
Kosie K1 17x7.5
The tires are Yokos, AVS EV100
Old Nov 23, 2004 | 09:27 AM
JCampos's Avatar
JCampos
AH ok. Well, if its rubbing badly Ill dremel the sh*t outta it
Old Nov 23, 2004 | 05:35 PM
jazmini's Avatar
jazmini
Remember that the offset on the Kosei may be more aggressive than the wheel you have in mind. :smile:
Old Nov 23, 2004 | 05:37 PM
JCampos's Avatar
JCampos
mines +45, what are the koseis?
Old Nov 23, 2004 | 06:01 PM
apexer's Avatar
apexer
As I recall the Kosie is 42 offset.
SosoMINI
Nov 22, 2015 03:17 PM
madmax88
Oct 26, 2015 01:45 PM
jwildr56
Aug 26, 2015 12:40 PM
Mini'mon
Aug 16, 2015 04:15 PM
