'09 clubmas S TPMS light
Old Dec 18, 2018 | 02:16 PM
edognight's Avatar
edognight
So, I have an '09 clubby s and the tire pressure light is on, flashes when you start the car, then it fades to a solid yellow. I scanned the car for codes, and my cheap code reader says 'front right and front left inactive' and the car computer says "Inactive", and "reset" on the dash with the turn signal stalk. It wont reset. SO Iam guessing both the front TPMS are out of battery, but my question is, do I just have the new one's put in, and do they have to be "scanned" ? I bought the bright orange ones from pelican parts, and I'm not sure what to do, but I would sure be happy if that stupid low pressure light went off. Thanks for any help.
Old Dec 20, 2018 | 02:29 PM
edognight's Avatar
edognight
So today I took the mini to the tire shop, and they said they could take care of it, which is always the kiss of death. They put the new TPMS sensors in the car and said to drive it for 20 miles over 20 miles per hour, which is more or less impossible to do. so everything is exactly the same as it was before, but I am 130$ lighter. I am still getting the code for front right and front left transmitter inactive, any help appreciated. This is my first car with TPMS and I am a little clueless.
Old Dec 20, 2018 | 03:12 PM
MiniToBe's Avatar
MiniToBe
did you check the fuses and/or reset is from the fuse?
also, did you check of the modules are actually plugged and not chewed. they are mounted behind the wheel well on on top of the horns and the other in an equivalent location.
finally, for the heck of it, swap the rears with the fronts and see if the code moves with it
Old Dec 20, 2018 | 05:31 PM
edognight's Avatar
edognight
MTB, thanks, I will do that and report back.
Old Dec 20, 2018 | 06:05 PM
ClubmanG's Avatar
ClubmanG
Edo,
You did not specify if you have had the car and it is a new issue, or if you just got it, with the issue.
Are all 4 wheels and tires matched diameter and size and brand?
Old Dec 21, 2018 | 06:06 AM
edognight's Avatar
edognight
All tires are the same size, one is a different brand. The car is new to me, it was a shell that someone took the engine out of, and I don't know anything about it, but it runs well, I am just getting sick of all these warning lights.
Old Dec 21, 2018 | 07:20 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We see these issues here and there. One thing that is important is the frequency on the sensors varies based on production date so if you don't get sensors with the same frequency they will never work so that is the first thing to check. Otherwise you need someone with real factory level MINI diagnostic computer to read out all the info at it will likely tell them exactly what is going on or has a test plan to test each part. This is how we do it in our shop.
Another option since you are in SC is bring the car to us in Atlanta and we will just disable and remove the tire pressure monitoring system so you won't have to fool with it in the future or ever buy parts for it again.
Old Dec 22, 2018 | 01:09 PM
edognight's Avatar
edognight
So I did some checking under the car, and I found a quick connect on both sides in front of the tires, with a white center, three wires. 20$ says that someone plucked the trigger sensors and I just figured it out.
Old Dec 22, 2018 | 01:53 PM
cristo's Avatar
cristo
Alliance Member
I’m betting with you.
The other good news is that the front sensor batteries
will now be good for another 5 - 10 years.
Old Feb 25, 2019 | 11:24 AM
edognight's Avatar
edognight
OK. SO back again with a tire thread. I plugged in the sensors, and this did not fix the code. Still getting the warning light, and it still says 'system inactive,' the code does move when you change the tire, it follows the position of the tire, but the code is still there. System will not reset, all sensors are plugged in and tires are same size and properly inflated. Any help appreciated. Or I might drive down to Atlanta and blank the stupid thing of this low tire pressure nonsense.
SmokeM
Tires, Wheels, & Brakes
Sep 11, 2009 07:38 AM
D Unit
Jul 20, 2008 11:02 AM
aem421
Oct 24, 2007 08:56 PM
aem421
Sep 19, 2007 06:51 PM
RallyMINI2005
Dec 13, 2006 01:52 AM
