Unknown Part Identification Help!
Old Dec 15, 2018 | 08:35 AM
jat2304's Avatar
jat2304
Hello Everyone,
I have been reading on the site since owning my mini. I recently had the timing chain rattle and decided to repair the turbo drain tube leak, my repairs went beyond that. LONG story short, I performed the walnut carbon blast and upon cleaning up under the car, I found a unique spacer(?) or cam piece. I was hoping that someone would be able to help identify it or point me in the direction of what it came off of.
As I'm sure I'll be asked what else did I repair, here are the repairs I performed was the replacement of the water pump, friction wheel, tentioner, oil pan gasket,all engine mounts, coolant pipe, fuel injectors, and removed the front end to access the turbo/catalytic converter. Any help anyone could provide would be great!
Thanks,
jat2304
Old Dec 16, 2018 | 03:21 PM
mkov608's Avatar
mkov608
That part looks a lot like the front bumper carrier inserts. I've you've had your MINI in the service position recently, I'll bet that's where these came from even though they look slightly different than the inserts used in my car. They go here on both sides. There are four of them, and they sometimes fall out of the front bumper carrier when putting it back together.
Old Dec 17, 2018 | 08:25 AM
jat2304's Avatar
jat2304
This was the first place that came to mind. The inserts are quite smaller, I had two of them that pulled off when removing the assy to begin my work. I appreciate the help though!
jat2304
Old Dec 19, 2018 | 03:18 PM
CantComplain's Avatar
CantComplain
Originally Posted by jat2304
Hello Everyone,
Thanks,
jat2304
I've got my 2008 MCS apart and have done all of that same work and never run across that part. If you have a theory let me know and I can check it out while I'm still in service mode.
Old Dec 20, 2018 | 03:58 AM
jat2304's Avatar
jat2304
Hi CantComplain,
I want to go a bit more in detail about the repairs I have completed. While tearing down for the oil leak. I found the previous owner used coolant stop leak clogging the aux pump for the turbo, clogging the turbo coolant galleys, there was oil coking with a bit of axial end play; so I'm replacing the turbo. So that lead me to perform the walnut blasting. Lastly, I remembered, I had the dealer replace the left and right wishbone bushings. I was wondering if this might be a part left over from that? Anyhow, I appreciate the help!
Thanks,
jat2304
Old Dec 20, 2018 | 05:13 AM
techman1's Avatar
techman1
Looks suspicously like the metal piece in the old thrust bushings I swapped off our BMW 325.
It came off in pieces, one looked like that. Is there an equivalent on our mini's?
Old Dec 20, 2018 | 09:41 AM
CantComplain
Hi CantComplain,
Thanks,
jat2304
WHat year and model do you have?
To me it looks like a lock washer that would fit over a shaft, so the shaft diameter would be the thickness of the inner hole. Haven't seen anything like that in my very similar travels. I took out the turbo and exhaust as one and never separated them though. I did order the fibrous washer to replace if I did though and the diameter looks similar, but it's perfectly circular and doesn't have the flat inner sides. I'm not a suspension guy in general and haven't mucked with it in this car, but it doesn't look like anything in the e90 I've done some suspension work on. Plus if you had that done at the dealer, how would it have ended up on your garage floor?
How confident are you it came off of your Mini?
Old Dec 27, 2018 | 08:23 AM
jat2304's Avatar
jat2304
Sorry for the delay in response, I have been a bit sick for the last week. This is the first European car in my garage and I'm not finding anything like it on realoem.com. My Cooper is a 2007 Mini Cooper S build 01/2007. I use to work a a diesel tech on Freightliners and sometime I would forget a socket, in my earlier years (it became expense!). I could see the dealer tech forgetting to grab it in the process of the repairs. I did not split the turbo. The oddity to me is that I only found it after blowing off the rear/firewall side of the engine.
Old Dec 27, 2018 | 10:27 AM
CantComplain
hope you’re feeing better!
my money would be on that piece not being from your car. Originally anyway. I’ve done that same work and have an empty hole on the firewall side of the engine at the moment and can’t see where it would go. And something that looks like a b. f. lock washer should be pretty easy to place. Maybe a leftover part or tool as you mentioned.
I ran ran across a couple engine removal threads with great pics of the engine bay without the engine in it—you may want to search for those and peruse to give you peace of mind. Are you encountering any issues with the car?
karizma23
Sep 7, 2018 12:56 PM
Ithinkwestink
R60/R61 Stock Problems/Issues
Mar 7, 2017 07:02 AM
05blkmini
May 18, 2013 02:52 AM
5904
Jul 4, 2012 11:10 AM
anyheck
Jan 7, 2010 01:09 PM
