JCW GarageInterested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
Hello, anyone running a boost vacuum/electric in their jcw? i want to put a gauge in my 13 gp and not sure where to start. I remember my previous jcw had two gauges on the sides but they were powered through OB2 connector..
Another question i do see for example a VIVId set up that pulls all the reading via ob2, would those readings be as accurate as running a vacuum based boost gauge ?
I like VDO gauges. I have used them for years and the quality is great. I currently run a mechanical boost gauge, along with an electric oil pressure gauge.
I am very fond of the P3 vent mounted gauge, but could not see spending that much.
So instead I went a different way. I had a mechanical autometer gauge for a bit, but it just wasn’t very accurate and it was noisy! After couple of tries, lol, I ended up with a Prosport EVO digital boost gauge. It reads from the boost tap like a mechanical gauge but goes to an electric sending unit. I put it in a gauge pod with a small prosport gauge visor to reduce glare. I am very happy with it. It’s accurate (tested against obd2 readings) and it looks good to, with a digital numerical readout along with a bar dial as well. Slap that sucker next to the tach and your good to go! Lol. ECS Tuning has them, I got mine on Amazon for a couple bucks less. It’s not an exact match, but with the red light wired up, it’s close to the factory orange.
There are a bunch of different ones out there. There are some that will mount off the back of the tach, there are vent mount kits. It depends on what you like and want to do. I didn’t want to make any holes anywhere if I could avoid it. I picked up a plain old black universal gauge pod with the gauge and the visor, it isn’t too big, and the depth is just right to butt against the dash so the wires slip right down inside under dash and are hidden nicely. That pod is made to be screwed or bolted on, but not wanting a hole if I move it, I went and got some industrial strength Velcro and double sided tape......and there it is! Ha ha
It sounds totally half-assed, I know. But it really worked great. It’s in there right as can be, stuck to the steering column and the side of the tach. You can’t even tell. I just need to paint the screws on the base black.
Looks good. Of course the problem is that wiring these gauges was a feat. And they are expensive. There is a problem, with a solution. I need to find the solution.
