R56 base cranck but no start(good battery)
Old Nov 9, 2018 | 10:33 PM
Tao's Avatar
Tao
I recently replaced the thermostat housing on my r56 base model because of an overnight problem
when i replaced everything back the car crank but didn’t start
the battery was tested and delivering 12.68V and 613/620 CCA
Old Nov 10, 2018 | 03:38 AM
MiniToBe's Avatar
MiniToBe
It felt like it wanted to start...tracebback what you did and make sure all connectors are right and pluged in and grounds are connected too.
Also, get an obd reading.
Old Nov 10, 2018 | 10:38 AM
Tao's Avatar
Tao
This is the results of obd test
Old Nov 10, 2018 | 11:49 AM
MiniToBe's Avatar
MiniToBe
Did clear the codes any these popped again? If so, check the MAF sensor and the MAP sensor on the intake manifold. Check the pins of these sensor to make sure they weren't bent.
Old Nov 11, 2018 | 12:04 PM
Tao's Avatar
Tao
Just verified but no results
Map and maf seems to be wired correctly
usafdrew
Nov 30, 2023 10:13 AM
kernelpanik82
Jan 21, 2018 08:21 PM
timvfx
Feb 20, 2017 01:01 PM
madminii
16
Aug 13, 2016 01:32 PM
XXLil MickXX
Mar 10, 2011 09:25 AM
