Car shutoff while driving
Old Oct 30, 2018 | 03:28 AM
Sunbul's Avatar
Sunbul
Hi ,
I have mini cooper s 2010 , while im driving its shutoff without any alarm and all electric fine and ac still running and it take few minutes to start again, I recantly change LPFP and install new crankshaft sensor and new throttle and new alternator with battery and its still shut off , i went to mini dealor he couldnt find any fault codes .
have any one has this problem solved?
Old Oct 30, 2018 | 04:41 AM
MiniToBe's Avatar
MiniToBe
Maybe fuse box behind passenger kick panel. You could buy a used one from ebay or car-part.com with a matching part number. It should be plug and play. Coding could be done later.
Old Jan 17, 2019 | 07:35 PM
chipusk8's Avatar
chipusk8
Did you find whats wrong? It happen to me i though it was Cas ews but looks like not, i got error K-CAN LOW and this is from insta D
Old Jan 18, 2019 | 01:40 AM
Sunbul's Avatar
Sunbul
I found interior fuse box has moisture cousing fuel pump shutoff and I order new fuse box next week will arrive now
im trying to find how moister come there!?
Old Jan 18, 2019 | 06:56 AM
aunknown's Avatar
aunknown
Might be the BCM. I just bought some parts from these guys not too long ago, was a good expierice.
Old Jan 24, 2019 | 10:35 AM
Sunbul's Avatar
Sunbul
Fuse box and vaccum line leaking
I found the reason the interior fuse box has wet cause the fuel pump shutoff and also the vaccum pipe hase leak
Old Jan 24, 2019 | 10:52 AM
chipusk8's Avatar
chipusk8
Looks like i have the same issue, did you replace it and do you have to reprogramed? I saw in other posts that should be plug and play
Old Jan 24, 2019 | 11:20 AM
Sunbul's Avatar
Sunbul
Yes i reprogram it but first check vaccum hose
hiherson
Mar 6, 2011 05:48 PM
oldhippie
Mar 12, 2006 12:22 PM
Thameth
19
Mar 29, 2005 10:53 AM
Chitown_COOP
Jan 18, 2004 06:58 PM
batticus
Sep 14, 2002 06:47 PM
