Electrical 2013 S rear fogs stopped working
Old Oct 15, 2018 | 06:31 PM
Nui's Avatar
Nui
I swear they worked before I made the LED switch.
The reverse lights work but not the rear fog. I put on the fog switch and the front fog works but not the rear.
Put in the original bulb for the fog section and still doesn't work.
What am I missing?
TIA!
Old Oct 15, 2018 | 10:00 PM
S-2013's Avatar
S-2013
Does the rear fog icon come on, is there a dedicated fuse?
Old Oct 15, 2018 | 10:07 PM
Nui's Avatar
Nui
Good question. I couldn't find the icon or switch. I'll look again...just downloaded a manual. Whoops. When the car is back I'll try the 'rear' fog light switch if its there. Ooops.
Old Oct 16, 2018 | 01:22 AM
S-2013's Avatar
S-2013
Rear fog switch is in the toggle bank under the HVAC controls. It's next to the passenger window switch and is separate from the front fog switch. You should get a "yellow" icon on the speedo face when on. If you installed LED bulbs, expect then to randomly flicker every few seconds due to the bulb check circuit. I did the same LED mod but coded the bulb check "off" using the Carly app.
Old Oct 16, 2018 | 09:27 AM
Nui's Avatar
Nui
Car just got back. There's no switch on the panel for the rear fog lights. Just a blanked out area. It certainly has them. Her mechanic said the computer might have fogotten the car has them and will need to be programmed.
Blanked out switch
Old Oct 16, 2018 | 09:53 AM
S-2013's Avatar
S-2013
Rear fog switch
Old Oct 16, 2018 | 09:57 AM
S-2013's Avatar
S-2013
I believe all 13 MCS's have the same lights in the rear bumper. It was an option to have them enabled with switch, symbols and icon illuminated on the speedo.
Old Oct 16, 2018 | 02:08 PM
Nui's Avatar
Nui
Guess this one didn't. Hopefully the computer can be programmed for it. Thanks for the clarification!
Old Oct 17, 2018 | 08:13 PM
Nui's Avatar
Nui
Just spoke to the mechanic. Without the optional switch as you have there's no programing that can be done. He said its a European thing and on US models the fog lights become a hard braking light.
Too bad. It gets foggy here and would've been nice to have them come on with the front fog light.
Old Oct 19, 2018 | 04:23 PM
anew742's Avatar
anew742
The mechanic is wrong! In fact, getting them to work as brake lights requires rewiring and not just reprogramming.
I also have a 2013 Cooper S and I got mine working just fine!
Spoiler
All you need to do is buy a replacement switch and put it into place. Then reprogram the car with NCS Expert and an OBD-II cable. There's a lot of great posts here detailing the whole process - which is how I found out and got mine working.
I can send you links with more info/files if you want.
Old Oct 19, 2018 | 04:29 PM
Nui's Avatar
Nui
That would be amazing! Do I buy the switch at the dealer? Most importantly, is the wiring there ready to be hooked up? I imagined it would take a long run to the lights. Please send the links. Really, really appreciate it.
Old Oct 19, 2018 | 05:47 PM
anew742's Avatar
anew742
The wiring and even the bulbs were already in place!
I got the toggle switch from Way Motor Works: https://www.waymotorworks.com/used-r...7-r58-r59.html
(link is for a used one, they also sell new. I bought used since it's half price and not noticeably different)
I reference this post for information: https://www.northamericanmotoring.co...beginners.html
And this one: https://www.northamericanmotoring.co...s-you-can.html
I got a cheap cable like this one: https://www.ebay.com/itm/BMW-INPA-K-...pid=1263694158 which works just fine
The reprogramming part didn't take very long, it just involved changing code from "nicht_aktiv" to "aktiv" lol
To get the toggle panel out, I just wedged a flathead screwdriver under each corner and shimmied my way across...not exactly elegant, but it worked
Sorry for the info dump! I don't have the time right now to explain properly, but I figured that this would be way better than nothing!
Old Oct 19, 2018 | 06:14 PM
Nui's Avatar
Nui
Just ordered and read the other threads. Can’t wait. Thanks again.
devilmotorsports
Feb 1, 2016 12:54 PM
KeyPlayaJim
Aug 9, 2013 07:14 PM
PawPaw
Jul 14, 2011 08:53 AM
Apple
Jul 4, 2008 12:19 AM
Dixie
18
Dec 9, 2003 10:45 PM
