2005 Mini Cooper S randomly dies
Old Oct 7, 2018 | 10:45 PM
Valience123's Avatar
Valience123
Okay, so I have a 2005 Mini Cooper S with 150k miles. There is no check engine light, I have only run 91 octane in the car EVER. I am having an issue. About every 200-600 miles the car will be idling at a stop light and randomly die. The car start right back up after with no problem. I can’t figure out what I’m the would would be causing this. It isn’t throwing codes.
ANY AND ALL HELP would be appreciated.
Old Oct 12, 2018 | 05:38 PM
coopermike29's Avatar
coopermike29
Fuel filter maybe partly clogged ??????
You should run 93 octane for best performance
what are the rpms when at idle when its fine and doesn't stall ?
Old Oct 12, 2018 | 05:56 PM
co0p3r's Avatar
co0p3r
Do you ever lose power while driving? I get that one every so often. It just dies and then restarts in a few seconds. I dont get a check engine either, and the motor is still under factory warranty, I have not bother to take it into MINI as its near impossible to reproduce.
Cooper
Old Oct 14, 2018 | 02:46 AM
Tgriffithjr's Avatar
Tgriffithjr
When was the last spark plug change? Run a bottle of Techron through it. If that doesn’t work start cleaning sensors. Start with the MAF. Look for vacuum leaks it intake leaks.
Kevin Tweet
Dec 3, 2015 10:18 AM
BC Clark
Jan 25, 2015 05:13 PM
adamseg
Dec 15, 2013 09:02 AM
minimic
Jul 21, 2011 07:54 AM
blkkouki
May 22, 2008 08:25 AM
