Electrical Where does this connector plug into???
Old Sep 13, 2018 | 04:51 PM
A383Wing's Avatar
A383Wing
I'm making some progress in getting the dead engine out of the car and swapping in the new engine......I got the header loose and found this rather large connector down under the header on top of the starter heat shield.......
What is it for and where does it plug into?? Vehicle is a '06 R52 MCS JCW car.....I have the same connector on the wire harness that I got with the wrecking yard motor also......looks like the other ends of those two rather large wires go under the under-hood fuse box......I'm just wondering what and where the end goes that I have in my hand
Bryan
Old Sep 13, 2018 | 06:09 PM
twokbolt's Avatar
twokbolt
Didn't we decide that was for the stock JCW airbox?
Old Sep 13, 2018 | 06:29 PM
A383Wing's Avatar
A383Wing
No, that was this little connector up by the cowl close to the air cleaner.....picture below of the connector that we talked about before....
This new connector has what appears to be #10ga wires in it....
Bryan
Old Sep 19, 2018 | 09:14 AM
Soul Coughing's Avatar
Soul Coughing
That is the plug for the electric hydraulic power steering
Old Sep 19, 2018 | 02:03 PM
A383Wing's Avatar
A383Wing
Thanks for the reply......I would like to see a pic of where it plugs into.....I can't find a home for it on my car
Bryan
Old Sep 20, 2018 | 06:36 AM
Soul Coughing
It goes on top of the power steering pump. May be hard to see if you've got your subframe fully installed. You should be able to fit it by feel though.
Old Sep 20, 2018 | 10:32 AM
A383Wing's Avatar
A383Wing
Ah, perfect.....found where it plugs into....looks like the connection terminals are a little bent up, probably from the previous people removing & replacing the engine assembly and not knowing what they were doing......once I get this drivetrain out, I'll take a pair of needle nose pliers and straighten out the terminals so the connector goes back on
Bryan
Old Sep 20, 2018 | 11:15 AM
RB-MINI's Avatar
RB-MINI
Looks like the plug housing which keeps it locked in and dirt and moisture out is broken off of the pump
Old Sep 20, 2018 | 01:15 PM
A383Wing's Avatar
A383Wing
Yea, there is something down there......will have to figure out a way to make the plug stay on, or possibly find this plug housing that you speak of.....I got no clue what it looks like, or even where to find one......whatever I have left is on the PS pump down there......
Just another item to find or fix on this car that I have dubbed "The Mini From Hell"
Bryan
ceddy1031
Jul 29, 2016 06:16 PM
R56typeS
Jan 13, 2014 05:24 PM
kylerogowski
Feb 6, 2012 08:09 AM
jbourne
Nov 21, 2010 09:54 PM
Drsms22
May 8, 2007 02:05 PM
