Navigation & Audio Nav System - Plug and play?
Old Aug 20, 2018 | 09:06 AM
nellis003's Avatar
nellis003
Hi all,
I found a Nav system for the 2008 Mini and was wondering if this is all I'd need to upgrade. I currently have a 2008 Mini Clubman with the base radio, and the unit I found has the speedometer with the nav screen and the CD player / selector "box" with the plug connectors in back. If I were to swap this out with my existing equipment, would I have a functioning nav system, or is there more hardware needed? Does the different speedometer work with the same input?
I understand that there's also a control component that comes as part of the center console - is this necessary for the nav to function?
Thanks,
Nick
Old Aug 20, 2018 | 09:16 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I don't specifically know the answer for your car. But from all the posts I've read when investigating similar thoughts on my car I've yet to come across one post that said - "sure simple plug and play and everything worked as great as I expected" Usually a lot of effort goes into installing and making things work. And then when you read closely, often things don't work so well, such as bad reception, etc.
Post up a link of the unit in question and maybe someone has experience with that model/brand.
Formel1
Jan 19, 2012 07:33 AM
GTS500
Marketplace (archive)
Sep 4, 2010 08:44 AM
DougVarney
Mar 31, 2009 02:13 AM
silver-mini-s
Jun 15, 2003 03:56 PM
trico
Feb 12, 2003 02:32 PM
