timing chain replacement
Old Jul 19, 2018 | 11:45 AM
gymnastcoach's Avatar
gymnastcoach
is it possible to pre tension the timing chain without a torque wrench? most i have seen dont measure that low. seems to be .6nm. can i just use the actual tensioner and then torque the sprockets? i have a 2009 r56 cooper s. breaking it down now, need some input before reassembly. thanks for any replies
Old Jul 19, 2018 | 01:11 PM
MiniToBe's Avatar
MiniToBe
I never used the pre-tensioner.
Old Jul 19, 2018 | 01:13 PM
jglover's Avatar
jglover
Just did mine last weekend. That seems to be what I did. You have the camshaft locking tool? I set the tool then took apart. On reassembly, I put the tensioner in then torqued the cam gears and then crankshaft.
Hope this helps and makes sense.
S-2013's Avatar
S-2013
Same here, just went ahead and torqued down the permanent tensioner.
Old Jul 19, 2018 | 03:51 PM
Notcompensating's Avatar
Notcompensating
I used the pre tensioner but just tightened it hand tight. It's better than the actual tensioner because the real tensioner is a spring type. The pre tensioner keeps the slack out while you torque it
Old Jul 20, 2018 | 11:45 AM
dmyer's Avatar
dmyer
That... it is what I did... there is a reason it is part of the procedure!!
Old Aug 25, 2018 | 07:10 AM
gymnastcoach
all back together and running better than ever, ended up getting most of the part at pelican. quick shipping and knowledgeable staff, thank you for all of the replies
kurtsunn
Apr 19, 2018 07:58 PM
weaver9000
Sep 14, 2015 05:48 PM
gbfan10
23
Dec 12, 2012 08:26 PM
5810
Nov 17, 2010 10:49 AM
