Help A Girl Out - New To Wrenching! 2013 Countryman Vanos Solenoid Replacement
Old Jul 18, 2018 | 03:24 PM
MINIGRL13's Avatar
MINIGRL13
So my Mini has 156k on now. Bought it new and love it. I’m not a mechanic or even close (Physical Therapist) but after receiving a quote for fixing my coils of $1050, I decided that I’m not dumb and can figure this stuff out!
Did a YouTube search and after buying the parts for $128, I was able to change the plugs and coils in about 30 Mins. I’m so excited to try to do the Vanos Solenoid that the dealership quoted me $500 to repair
I’ve read that the solenoid can be a challenge. Are there any recommendations that you guys can give to help a girl out before I try it?
Thank You In Advance
Pic #1 - Winston & My Mini
Pic #2 - Day I bought MINIGRL
Attached Thumbnails Help A Girl Out - New To Wrenching!  2013 Countryman Vanos Solenoid Replacement-04fd6b0b-cf81-41d1-bda9-49ac7fbd73b6.jpeg   Help A Girl Out - New To Wrenching!  2013 Countryman Vanos Solenoid Replacement-1b55646d-5402-48bc-b5a4-cbe0a2751ae8.jpeg
Old Jul 18, 2018 | 03:48 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Suggest you post this in the Gen2 Stock Problems/Issues section as well. Will get more coverage I am pretty sure they are both the same engine.
Sorry I am a Gen1 owner, you know the type that instead of Bluetooth we got a Dixie Cup and String . . . . .
Whine not Walnuts
And that is a great looking MINI.
Old Jul 18, 2018 | 06:59 PM
Minidogger's Avatar
Minidogger
The dog is guarding it close!
Old Jul 18, 2018 | 09:50 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I passed on doing the Vanos when it needed changing. The one in front is pretty easy to get to, but the one in the back was too difficult for my old body to deal with. Good for you going after these things with no prior experience.
The guy who changed out mine did an oil engine flush first with LubriMoly flush product as the oil was a bit gunked up from prior owner probably not changing it enough.
An Indy mechanic should be able to tackle if for less money than the dealer if you decide to pass.
Old Jul 19, 2018 | 06:54 AM
MINIGRL13's Avatar
MINIGRL13
My ck engine light is coming on so that’s why I’m trying to change it. After changing the plugs/coils the ck engine light went off, but shortly after it came back on with the P0015 code for the vanos solenoid.
On the the bright side it’s no longer throwing the other code with the new coils! No more reduced engine power mode... YEAH!!
i guess I didn’t realize there were two different vanos solenoids? Font and back?
Old Jul 19, 2018 | 07:12 AM
Whine not Walnuts
I have seen videos to change the front one on a R56, there may be some for the back one. The question for the Gen2 engine folks is whether both need to be changed when the code is thrown.
Old Jul 19, 2018 | 09:20 AM
MiniToBe's Avatar
MiniToBe
before doing the vanos, check the timing. Not sure if the '13 N18 engine got the revised 82mm tensioner, but it is worth checking first. remove the cover and take a look. you'd need some muscle to turn the engine by hand clockwise to observe the timing.
https://www.newtis.info/tisv2/a/en/r...shaft/DdAtK5Jc
Old Jul 19, 2018 | 09:58 AM
MINIGRL13's Avatar
MINIGRL13
I have yet to buy the vans sensor. I bought the coils at rock auto but can’t seem to find the sensor there on their website.
Any recommendations on where to purchase it?
Old Jul 28, 2018 | 08:59 AM
chaswilson's Avatar
chaswilson
They are under "Engine" then "Variable Valve Timing Solenoid" at Rockauto. I bought 2 on Amazon @ $31.90 from "Mr. Fix" and installed back in March and no issues since. Front one is very easy. Back not so much, had to remove large intake hose and then use a mirror to see what i was doing. Make sure and use magnetized bits to keep from dropping the screw, ask me how I know that, took me longer to retrieve the nut then to do the install.
Old Aug 20, 2018 | 09:21 PM
dmath's Avatar
dmath
Beautiful car but I’m more envious of your garage floor.
greentrees
Jun 22, 2020 02:27 PM
kurtsunn
Jul 28, 2018 12:12 PM
Juder73
Mar 5, 2018 07:03 PM
sarge21rvb
Oct 14, 2017 12:18 PM
MasterExploder
R55 :: Clubman Talk (2008+)
Oct 10, 2012 07:22 AM
