R56 Tachometer Swap and now problems
Old Jan 31, 2018 | 09:47 AM
MazMini's Avatar
MazMini
I got my new to me 2013 Cooper S and hated the new Tach vs my 2007 that showed the temp and time. While at the junk yard there was a 2007 that had the gauge pods built into the side.. Well little ole me bought them for $50.00 came home and installed it. Mileage showed 50,xxx which is the correct mileage and all was well.. Fast forward 3 months and Im going to the gym and look down and its 122,000!!!
I swapped the old gauge back into the car but now it briefly shows 52,xxx (which is correct) but then goes back to 122,xxx. I pulled the terminals off the battery for a couple days when I was away but that didnt help. My question is will it figure it out and go back to the 52,000?
Thanks!
Old Feb 1, 2018 | 07:16 AM
MiniToBe's Avatar
MiniToBe
oh my...it happened to me while I was rebuilding my flooded 2013 mini. Basically, the concept is the computers will sync data (not all, but some are "sync-able") and mileage could be one of those data entries. It will store the highest number and will always add the numbers.
When I had that issue, I called my "service tech" out in IL and was able to restore my mileage. I had to send him the ECU, CAS, keyfob, cluster, and tachometer. They all needed to be synced the same time.
Old Feb 1, 2018 | 11:02 AM
MazMini's Avatar
MazMini
I might need his info!
Old Feb 1, 2018 | 11:11 AM
MiniToBe's Avatar
MiniToBe
precisionecu@gmail.com technician name is Andy. Tell him Salah from philly referred you. tell him the story and what he needs to get it fixed .
he is also here on ebay https://www.ebay.com/usr/6167
pa.now
Electrical
Jun 5, 2015 10:33 AM
Amytheallen
R55 :: Clubman Talk (2008+)
Aug 18, 2012 08:52 PM
Autoxser1975
Jun 12, 2011 02:27 AM
WEEGIT
Feb 11, 2006 06:22 PM
