Drivetrain fuel pressure regulator upgrade?
Old Jan 19, 2018 | 07:23 AM
gsfent's Avatar
gsfent
Trying to add a little more fuel pressure. Is there any upgrade to our FPR? We run 3.5 bar, can it be tweaked or is there a 4 bar FPR that works?
Thanks.
Regards,
Jerry
Old Jan 19, 2018 | 02:21 PM
BlwnAway's Avatar
BlwnAway
I don't think it can be changed without bypassing the factory vacuum unit and going to an aftermarket regulator.
There may be a way to disassemble the modulator but it would be hit and miss as to what you could actually do to it. But who knows, it is just a fuel grade vacuum modulator. Maybe some other cars use a 4 bar or higher that could be swapped in, but honestly the aftermarket route would be much simpler.
This it's just one of those mods that most people don't need, and those who do have already used so many aftermarket solutions in their cars, they just go that route here as well.
I've actually measured 53 psi (3.65 bar) at the rail, if that matters.
And for those who are wondering, the factory fuel pump is capable of about 62+ psi (4.2 bar).
Jerry, just wondering, is this something you know you need, or are worried you might? Unless your running e85 or something higher, the OEM system has supported 750cc injectors with pump gas. And are you actually looking for more pressure or are you maybe looking for more flow? That can be achieved with a pump upgrade.
Old Jan 20, 2018 | 11:23 AM
gsfent's Avatar
gsfent
And for those who are wondering, the factory fuel pump oohs capable of about 62+ psi (4.2 bar).
Long story. PM sent.
Regards,
Jerry
screwed36coupe
Sep 14, 2013 03:35 PM
SteveS
Jun 27, 2012 12:49 AM
Brandon_coopers
Jan 25, 2011 08:57 AM
phone
May 20, 2007 09:25 PM
Nomios_SLC
Feb 21, 2005 07:22 PM
