R50/53 boost gauge and fuel pressure regulator question
Old Jan 21, 2011 | 03:13 PM
Brandon_coopers's Avatar
Brandon_coopers
From reading on the boards, I see the best way to get a reading for a boost gauge is to T it off of the fpr vacuum line. My question is, won't the extra length of line interfere with the vacuum levels the fpr gets and therefore throw off the fuel being injected? It seems that extra volume inside the vacuum line to the boost gauge will cause a slight variation between the actual manifold vaccum pressure and what the fpr expects to receive. Thanks
Old Jan 21, 2011 | 05:05 PM
NMgokart's Avatar
NMgokart
The volume inside the line is minuscule, and you should be T-ing off of the line to the BPV anyway. Or use a Scanguage and let the car's sensors do the work for you.
Old Jan 21, 2011 | 08:59 PM
Some Guy's Avatar
Some Guy
Your correct, it will throw it off, however it probably isnt enough to matter.
Old Jan 25, 2011 | 08:57 AM
Brandon_coopers
I just wouldn't want to be going WOT and have my fuel off because its not reading the correct volume. So what are the pro/cons of T-ing off the bpv instead of the fpr?
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
wkp1219
Nov 13, 2015 07:52 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
