What do you guys think of these rotors?
"RDR Non-Concentrically Slotted Brake Rotors"
http://www.mini-works.com/chassis.html
(about hallf way down the page)
They look 'interesting' to say the least...
Anybody have them?
Anybody have them?
Look interesting, but as always, expensive. I have come to the conclusion that inexpensive, decent quality, non-slotted rotors are going to be my route. I do a lot of track days and Brembo is offering an OE sized rotor, non-slotted, etc. for about $48.00 @ through Tire Rack.
no, I am betting he is getting it because he does track days, and all that slotting, drilling, does is lower mass and surface area and increase the chance of cracking a rotor.
With the stock brake system, going through rotors is a fact of life. Getting a good price on a good rotor is an awesome combination with track days.
Now if I could just decide on getting the 15" race brake kit......
As long as the rotor diameter remains stock sized don't expect that much better performance. Maybe a little benefit to remove gas and reduce heat build up.
Your biggest benefit comes from the pads you match with your event or use of the MINI. Rotors and pads do wear out. If your track pads grind down and ruin your rotors don't expect the dealer to replace those rotors. If your stock pads grind your rotors then take it to your service dept if within the warranty period.
If you want more stopping power then you'd need to look into a brake kit. We are lucky to have several good options from RLMini (B3) and from TCE brakes.
The least expensive braking improvement for track use, after pads and fluid, will be cooling ducts. Noticeable improvement in fade has been realized even without back plate modification.
I need to file that pattern away. I think I'm up to about 16 different slot patterns on file now. All of which claim to be the 'best'. Of course it is.
The rotors pictured will do little at all to change brake effectiveness. That's why the comments on the pads. PADS do make a difference. Granted any slotted rotor will vent gasuous build up a bit (so too do slotted pads) but zip for torque. And if they are the same thickness they have the same thermal capacity as well. Other than that, it's just a new twist (so to speak) on gas slots.
You could get dizzy watching those eh?
*someday I'll post a pic of my exclusive 'surface slot' rotor... nothing comes close...
pic needed
Ducting is my next step. I'm trying to figure out how to do it without interfering with the fog lights. Alex at Tire Rack explained it, but looking at my car I don't quite get what he meant.
Alex
ducts
here is a pic of the ducts that JCW sells. they are not available in the US. i've tried and to this day have not been able to get them. they can only be sold when installed by a JCW's dealer, that means you have to get them in the UK. i've heard of some US dealers trying to make some but it looks like they are slow to come to market. i'm now looking for a big brake kit. the cooling ducts would be a much cheaper path but i've yet to find some. if anyone knows about some please let me know.
backplate/dust shield
The MINI Bentley manual references the backplate as a dust shield. I decided to remove mine when I installed the Wilwood 11.75" Race Kit. Part of me thinks that it is helpful in that it channels air for cooling.... then part of me thinks that without it, there will be better cross-flow. If it is there just for dust, that's fine... but I feel that maybe it also keeps heat off the ABS line there. To be honest, I contemplated dis-assembly of the kit to install these plates again, but good ole red Loctite dissuaded me from going that route.
Anyone else running without these plates?
I too put the wilwood race 11.75 kit on and took off the dust shields. So far no issues- was told heat shielding on wire by brakes is all that is needed- haven't done that yet though.
Re cooling, i removed fog lights & bracket & cut hole in fender liner to let some cool air reach brake. Obviously not as good as JCW kit, but very easy and cost 0.
thebordella
Aug 31, 2015 01:37 PM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
