Gear selector stuck, won't go into Park
Old Sep 13, 2017 | 10:25 PM
dchernikoff's Avatar
dchernikoff
I have a 2007 Cooper-S Hatchback, automatic. The silver button/latch on the shift lever is stuck and won't depress, so I can only shift between D and N, it won't go into park. Any ideas how I can fix it? I can't even see how you can remove the lever...
Thanks for any help!!!
-Dan
Old Sep 14, 2017 | 05:40 AM
MiniToBe's Avatar
MiniToBe
the lever pulls upwards. watch your face and teeth. Try to tap it down first to see of the button releases.
Old Sep 14, 2017 | 08:08 AM
dchernikoff
Thanks I'll give it a go!
Old Sep 25, 2017 | 02:50 PM
Agent's Avatar
Agent
Same car same issue
Any luck?
Old Sep 25, 2017 | 03:23 PM
dchernikoff
Yes! I finally got a chance to work on it yesterday -- I've been out of town. I confess I was a bit skeptical that just tugging on it would work. But I tried it -- put it in drive, started pulling up with a lot of force while gently twisting it. And suddenly POP it came out! The original problem I was having was that the spring, on the button you push that lets you move the shifter, had stopped working so the button would just move without auto-returning. Which was fine until I was fiddling with it and it got stuck in the out position and wouldn't depress anymore, so I couldn't shift into park or reverse!
After I popped the **** out, the button started moving again so I was able to move it to the depressed position, replace the **** back onto the shaft, and now it works like before. Whew. I went ahead and ordered a replacement, though, because I don't want it to get stuck like that when someone else is driving the car.
So yes, it does just pull out and push back in. You don't even need to remove the cloth boot/cover, the **** is above and not attached to the cloth part.
Thanks @MiniToBe for your help!
-Dan
Old Mar 8, 2019 | 12:52 PM
CACHIMBUDO's Avatar
CACHIMBUDO
Dude your awsome thanks that save me some cash. 09 mini cooper clubman s.
Old Mar 8, 2019 | 12:55 PM
MiniToBe's Avatar
MiniToBe
my pleasure brother
Old May 11, 2023 | 04:41 PM
toskyman's Avatar
toskyman
Gotta love the net & support forums
This morning the exact same thing happened to my Mini Cooper S 2012 and this thread helped me deal with the issue. I am also ordering a replacement gear **** so I don’t have to got through this again!
Thank you @MiniToBe and @CACHIMBUDO!!!
Old May 11, 2023 | 04:48 PM
MiniToBe's Avatar
MiniToBe
We're definitely happy to help and support the community 😊
hizhonor
Dec 11, 2024 06:16 PM
TechTurbo
Jul 22, 2022 10:36 AM
sungjk
Jun 16, 2019 05:28 PM
guka747
Mar 6, 2017 09:22 AM
pmustang
31
Apr 25, 2008 08:05 PM
