Gear selector stuck, won't go into Park
I have a 2007 Cooper-S Hatchback, automatic. The silver button/latch on the shift lever is stuck and won't depress, so I can only shift between D and N, it won't go into park. Any ideas how I can fix it? I can't even see how you can remove the lever...
Thanks for any help!!! -Dan |
the lever pulls upwards. watch your face and teeth. Try to tap it down first to see of the button releases.
Thanks I'll give it a go!
Same car same issue
Any luck?
Yes! I finally got a chance to work on it yesterday -- I've been out of town. I confess I was a bit skeptical that just tugging on it would work. But I tried it -- put it in drive, started pulling up with a lot of force while gently twisting it. And suddenly POP it came out! The original problem I was having was that the spring, on the button you push that lets you move the shifter, had stopped working so the button would just move without auto-returning. Which was fine until I was fiddling with it and it got stuck in the out position and wouldn't depress anymore, so I couldn't shift into park or reverse!
After I popped the knob out, the button started moving again so I was able to move it to the depressed position, replace the knob back onto the shaft, and now it works like before. Whew. I went ahead and ordered a replacement, though, because I don't want it to get stuck like that when someone else is driving the car. So yes, it does just pull out and push back in. You don't even need to remove the cloth boot/cover, the knob is above and not attached to the cloth part. Thanks @MiniToBe for your help! -Dan |
Originally Posted by MiniToBe
(Post 4329890)
Originally Posted by CACHIMBUDO
(Post 4455361)
Dude your awsome thanks that save me some cash. 09 mini cooper clubman s.
Gotta love the net & support forums
This morning the exact same thing happened to my Mini Cooper S 2012 and this thread helped me deal with the issue. I am also ordering a replacement gear knob so I don’t have to got through this again!
Thank you @MiniToBe and @CACHIMBUDO!!! |
Originally Posted by toskyman
(Post 4651642)
| All times are GMT -7. The time now is 03:52 PM. |
