F55/F56 Automatic shift selector lever lock solution
Old Jul 11, 2022 | 11:28 PM
TechTurbo's Avatar
TechTurbo
I found the button on the front of the gear shift selector lever somewhat hard to press when moving away or into the P parking position with my disabled right hand. Any creative solutions of the problem? I tried a rubber band, but the shape of the shifter prevented the rubber band to put pressure on the button. A solution is to replace the Automatic Shift **** with the one made by CravenSpeed which lift up on the **** to operate the shift lock release.
Old Jul 12, 2022 | 10:30 AM
TVPostSound's Avatar
TVPostSound
Thats an option. Do you think it would be easier to pull up, the button presently is a lever action, maybe pulling up might be more effort?
I thought about getting one myself.
Read the reviews, there have been fit issues that needed a workaround.
I cant think of any other solution for you.
Old Jul 12, 2022 | 10:59 AM
TechTurbo's Avatar
TechTurbo
In my case it is easier to pull the entire shifter up using my whole hand instead of the button which is relatively stiff. Is not clear if the button mechanism is mechanical or electronic... there must be a solution.
Old Jul 12, 2022 | 11:17 AM
chrunck's Avatar
chrunck
Have you considered importing a right hand drive MINI?
I've never taken apart the automatic shifter, but maybe it's possible to replace the spring inside with something less stiff?
Old Jul 12, 2022 | 02:12 PM
TVPostSound
I looked at realoem, and newtis.
The gearshift **** is one assembly with the rod. No service information available to disassemble to maybe cut spring or replace with weaker spring.
Old Jul 12, 2022 | 02:15 PM
TVPostSound
It looks mechanical. The new shift **** locks to the rod, pulling the **** up pulls the rod out of the cog underneath, and a spring returns it/holds it down.
The OEM **** is one with the rod, I assume a lever is within the ****.
I think the Cravenspeed is your only choice.
Old Jul 12, 2022 | 04:30 PM
TechTurbo's Avatar
TechTurbo
Thanks for looking into it, appreciated!
Old Jul 12, 2022 | 04:37 PM
TVPostSound
I completely understand, I cant use a clutch anymore.
Old Jul 18, 2022 | 07:20 PM
TechTurbo's Avatar
TechTurbo
Update - I installed the Automatic Shift **** by CravenSpeed and I am happy with the results. It is much easier to lift the **** than pressing the button on the OEM shifter.
One can also choose to not install the Lockout Rod or spring to bypass the shift lock release altogether which I did. Thanks everyone!
Old Jul 19, 2022 | 12:04 PM
TVPostSound
Good idea, but Im the type that wouldaccidentaly go in reverse at 50,ph with the lockout!!
Old Jul 19, 2022 | 01:29 PM
TechTurbo's Avatar
TechTurbo
Based on the numerous YouTube videos, the computer should ignore the gear change from D to R or P while the car is going... at least when > 5 - 10 mph. Someone here is brave enough to try it?
Old Jul 22, 2022 | 10:36 AM
Tio Barry's Avatar
Tio Barry
The later cars w DCT have a different configuration shifter. May or may not be compatible. Check out at the dealer(?)
Mini242
May 18, 2020 12:12 PM
mitymouse
R55 :: Clubman Talk (2008+)
Aug 29, 2017 09:11 AM
cumang0
Jan 11, 2014 10:48 AM
Dr Obnxs
Feb 7, 2007 12:56 PM
MiniKJ
Feb 26, 2006 08:14 PM
