Grinding Reverse
Old Sep 20, 2004 | 04:35 PM
danieln667's Avatar
danieln667
Grinding Reverse
I know there have been a bit similar threads on this but it was different circumstances than mine. Whenever I try to shift into reverse my gear grinds unless I really push it hard into reverse. Is this a common thing with MC's or should I have this looked at?
Old Sep 20, 2004 | 07:33 PM
lotsie's Avatar
lotsie
I find the same thing with my 03 MC.What I do is go to 2nd gear,than back to reverse,if that still makes it hard,I release the clutch,go again,always is smooth then.Most times,it's not an issue.I like my trannySo far
Old Sep 20, 2004 | 07:46 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I have an 03 MCS and when shifting into reverse I never get grinding.
Make sure that you clutch pedal is depressed fully before you shift. Push the shift **** fully left first then down into reverse in a two step process slowly and deliberately.
I get grinding only in 2nd to third when shifting too quickly. If I slow down and pause in neutral just a tad , shifts are much better.
Old Sep 20, 2004 | 08:08 PM
PEP's Avatar
PEP
Coordinator ::Bluegrass Minis
In my 04 MC I too get the grind now and then. It seems as though, if the car is rolling at all, it will grind. I also now have a habit of wobbling the shifter back and forth a couple of times before I go for reverse. This means I am holding the clutch in for just a bit longer, but it seems to work. Also, if I count to ten using only even numbers...it never grinds.
Old Sep 20, 2004 | 08:09 PM
ecfwho's Avatar
ecfwho
When I first got my MC I would sometimes grind it, thinking I was in reverse. For some reason, sometimes it didn't want to shift all the way. When I got used to the car, I could tell when it was in gear or not. If moving the stick a little to either side doesn't work, I also found that I could just go in reverse slowly as if it was in gear while still moving the stick back at the same time. The stick would kind of ease into reverse without grinding. Sometimes, when I'm not careful it does grind. Also, I don't have a clue if this technique is bad for the car.
Old Sep 20, 2004 | 08:16 PM
lotsie's Avatar
lotsie
Yes my shifts into reverve are always over than back,in 2 steps.But sometimes the Midlands does not want to go,I don't push it and get a grind,I go to second fast,back to reverse,works 99% of the time,if not release the clutch,engage clutch,back up
Can't seem to figure out what leads to the problem.But only ever happens when I start the car and need to back up, never while I stop and back up
Old Sep 20, 2004 | 08:21 PM
lotsie's Avatar
lotsie
Grinding is BAD,do whatever does not cause it
Old Sep 20, 2004 | 08:28 PM
MINIDean's Avatar
MINIDean
MCS models have a syncronized reverse gear, meaning they will never grind if you're rolling and put it into reverse. MC's though, that's a different story.
Keet
Suspension
Aug 30, 2016 03:46 PM
unxpectederror
Oct 22, 2015 12:16 PM
FatherG
Oct 3, 2015 05:06 PM
gknorr
Oct 1, 2015 09:20 AM
ericf1993
Sep 26, 2015 03:58 PM
