MCS Battery Smell?
Old Sep 20, 2004 | 04:26 PM
tornado's Avatar
tornado
MCS Battery Smell?
Anyone with a Cooper S ever go into the boot (trunk) and lift up the floor panel to look at the battery? Last time I did this, I got a strong whiff of sulphuric acid. This is quite normal for a lead/acid battery to give off, but what's of concern is that on the MCS, these vapours are released inside the car instead of the engine bay. Though I've never detected them from the driver's seat, I'm sure they are present and measurable in the air. Sulphuric acid is, I believe, a known cause of male infertility...
Mike.
Old Sep 20, 2004 | 04:28 PM
El Diablito Rojo-N20Mini's Avatar
Mike.
sounds much better than a vasectomy..... where can I sign up????
Old Sep 20, 2004 | 04:35 PM
tornado's Avatar
tornado
I guess it's to reduce the chances of us having kids to put in the tiny rear seat
Old Sep 20, 2004 | 06:32 PM
kenchan's Avatar
kenchan
In my case, it didn't work. My wife's 2cm tonight. any day now
for Mini-Kenchan.
oh btw, no, when i lifted the trunk floor, my battery did not have any
smell.
Old Sep 20, 2004 | 06:37 PM
for Mini-Kenchan.
smell.
congrats.... have any names picked out?
Old Sep 21, 2004 | 05:58 AM
Dave&Stacy's Avatar
Dave&Stacy
Hmm...doesn't the MCS doesn't use a "Gel-Cell" type battery??? If not, I think I will be looking into an Exide Orbital or Optima Red Top or something like that.
Old Sep 21, 2004 | 06:24 AM
Jdewey's Avatar
Jdewey
battery
As I recall mine has a "drip tube" like a motorcycle battery that leads out of the battery box.
If you are Charging or discharging the battery at a high enough rate to cause Acid fumes in the battery box, you should investigate why.
JD
Old Sep 21, 2004 | 08:10 PM
KatanaPilot's Avatar
KatanaPilot
The MCS battery definitely should be vented to the outside via a tube. Take a good look to make sure your vent tube is properly connected. And make sure the other end of the tube exits the vehicle.
Old Sep 22, 2004 | 04:59 PM
lotsie's Avatar
lotsie
Does MINI rely on the vents out the bottom of the boot to clear the air? I know that in my MC,the air does not move as well when the navigator is sleeping in front of them.
Getrieben
Sep 12, 2024 07:03 AM
Getrieben
Aug 17, 2016 06:32 AM
bansasn
15
Sep 4, 2015 01:24 PM
PParker74
R55 :: Clubman Talk (2008+)
Aug 30, 2015 04:20 PM
scottrn
Aug 22, 2015 07:26 PM
