My Code 2885 Boost Deviation Solution
Old Oct 3, 2016 | 07:42 AM
OUMX117's Avatar
OUMX117
I wanted to share my experience with the forum since most of the information I used to solve this issue I found here on NAM. My 2009 Mini Cooper S was throwing a 2885 code pretty much every time you pushed the throttle past 3/4 it would go into 1/2 power mode. I could clear the code and it would do this again and was very repeatable.
I started by removing all the heat shielding from the turbo and downpipe. Once I had the downpipe off I was able to determine that my catalytic converter was not clogged, however the gasket from the turbo to the downpipe was blown out. A quick trip to my local Mini dealer and I had the new gasket. I also checked the travel on the wastegate actuator. The spec says it should not have more than 8mm of travel. When I checked mine it had almost 18mm. I adjusted the rod, verified the travel with a dial indicator and a vacuum pump, and put it all back together. I also replaced the all of studs on the turbo and had to re-tap one of the holes on the turbo as it became galled during removal.
Once I finished up the oil change and air filter cleaning I test dove the car and the boost code was gone. I could drive the car as hard as I wanted and I could not get the car to go into half power mode. I was very happy with the outcome. I was preparing for the worst(turbo replacement) and hoping for the best. Now all I have to do is figure out why my *^&* gas cap light keeps coming on and this car will be back to 100%. Hopefully it’s just the leak diagnostic pump, but that’s a task for another day. For now I’m enjoying being able to accelerate quickly without fear of reduced power. Thanks to everyone on this forum for the wealth of knowledge that I was able to pull from to get this little car back on the road.
Old Oct 4, 2016 | 07:26 AM
JayDubYa2003's Avatar
JayDubYa2003
As a new member and someone that is new to the Mini community it's great to see posts like this.
Congrats on not only finding your issue but getting it fixed as "easily" as possible.
Old Oct 4, 2016 | 07:30 AM
OUMX117's Avatar
OUMX117
It really was great to be able to fix the issue by making some adjustments rather than needing to buy a $900 remanufactured turbo. The car is a completely different animal now. It builds boost almost instantly and is much more pleasant to drive. I always thought it was zippy before, but now that the wastgate is working properly it is quicker in normal mode than it ever was in sport mode. I really enjoy driving the car again.
Old Oct 4, 2016 | 08:17 AM
bugeye1031's Avatar
bugeye1031
Moderator
Nicely done! and thanks for sharing.
How many miles on your '09 when it started showing 2885?
Old Oct 4, 2016 | 08:19 AM
JayDubYa2003
bugeye1031 by chance have you owned or do you own a 2002/2003 WRX?
My Xbox Live screen name is BugeyedNBoosted ;-)
Old Oct 4, 2016 | 08:22 AM
OUMX117's Avatar
OUMX117
We bought the car with 84,000 on the odometer. It showed up very infrequently around 89-90K but had been showing up more frequently as the car now has 96K on it. I have no idea how long the wastegate had been that far out of adjustment, but now its all dialed in and good to go! I still need to replace my diagnostic leak pump on the EVAP system and then it will be completely CEL free.
Old Oct 4, 2016 | 08:36 AM
Dr. Spade's Avatar
Dr. Spade
OP this is some really useful info as that code can come up for several reasons.
Mine was a diverter valve at one point (replaced). On a tune I will get it when boosting hard in a higher gear.
I am leaning towards the wastegate being the issue as well.
I need to learn how to adjust a wastegate I guess. I was going to just replace the turbo.
Old Oct 4, 2016 | 08:51 AM
OUMX117's Avatar
OUMX117
I thought the same thing when I first started getting code 2885. I went ahead and replaced my diverter valve with one from Way Motor Works. This seemed to temporarily solve my issue. About a week later I was back in the same position though.
Another confession associated with the repairs...... When I went to clean my air filter (drop in K&N unit) it was really dirty. So that could have helped out somewhat as well. All I know I know is that now it is a completely difrerent machine.
Old Aug 14, 2020 | 04:44 AM
rmathiesen's Avatar
rmathiesen
Waste gate adjustment
where can I find how to adjust waste gate for turbo. I have a 2009 clubman with 89k and just got that 2885 code.
Old Aug 15, 2020 | 05:56 AM
OUMX117's Avatar
OUMX117
https://www.pelicanparts.com/techart...te_Testing.htm
Way2Fst4U
Aug 15, 2020 05:57 PM
uni
Aug 20, 2018 07:24 AM
jacknk
Nov 3, 2017 12:09 PM
HealyRacing
Oct 4, 2017 08:06 AM
Yeah.ThatsRice.
Sep 23, 2010 08:33 PM
