R50/53 Another cooling fan thread
Old Aug 22, 2016 | 09:50 AM
50shadesofr53's Avatar
50shadesofr53
I've searched and searched...
I can't find anyone having the same issue as me.
I have replaced the cooling fan relay(s) on my 06 mcs about 3 times now. As soon as I would replace it the fan would work for about a week as it was supposed to. Now I am having the issue again. I changed both relays under the hood but this time, the fan doesn't work! I just replaced the PS cooling fan since it was a gooped up mess and didn't spin.
Is it time to change the fan?
I think not since the A/C trick works still
Any ideas?
Old Aug 22, 2016 | 10:02 AM
RB-MINI's Avatar
RB-MINI
Not clearly understanding your post since it refers to the cooling fan and the power steering fan. Is the issue the low speed mode on the main cooling fan on the radiator is not working? If so, I'm not sure why it would temporarily work when replacing a relay. Usually the issue is with the resistor burning out on the fan that controls the low speed.
Old Aug 22, 2016 | 01:51 PM
50shadesofr53
Someone told me the PS fan and the rad fan were connected in circuit, must be wrong!
I also never hear the PS fan come on.
I believe the term is low speed? If I leave the car idling it will get as hot as it wants. I get scared at 220 and turn the ac on. The fan then comes on and brings me back down to regulating temp of 185.
But if I'm driving I stay at 185-190
Old Aug 23, 2016 | 04:35 PM
Hound_va's Avatar
Hound_va
As RB said, the resistor on your fan assembly has failed, hence you have no low speed fan operation.
Old Aug 23, 2016 | 05:20 PM
RB-MINI's Avatar
RB-MINI
If that's your issue, here's a huge 130+ page thread of info:
https://www.northamericanmotoring.co...-solution.html
After reading some of the beginning, you can skip to the back for the most current solutions and parts sources to fix the problem.
angeltrain31
Jun 12, 2016 05:58 AM
twoj's
Apr 14, 2016 01:14 PM
blackprophet
R55 :: Clubman Talk (2008+)
Apr 12, 2016 02:44 PM
Frixos
Apr 3, 2016 06:12 PM
greatgro
Jul 24, 2002 09:01 AM
