R50/53 Hatch won't open, HELP
Old Aug 6, 2016 | 12:26 PM
Drumsound's Avatar
Drumsound
I noticed some rattle in my hatch, so I went to try to adjust the stoppers and it won't open. I used it yesterday, and even went to the carwash today. so I opened it to dry the inside.
Neither key will engage the hatch unlock. Even with the car running it won't open. I assume this is electrical and hopefully simple.
Ideas?
Old Aug 6, 2016 | 12:33 PM
RB-MINI's Avatar
RB-MINI
Check under the bottom of the rear seat cushion. The later first gen's have a manual release cable, but sometimes they were retrofitted by owners of earlier cars. What year is your car?
Old Aug 6, 2016 | 12:34 PM
Drumsound's Avatar
Drumsound
Mine's an '06. Thanks.
Do I need to remove the seat?
Old Aug 6, 2016 | 12:40 PM
RB-MINI's Avatar
RB-MINI
No, you should be able to pop the front clips up and squeeze your hand under. The cable is routed from the passenger side and the loop to pull it is in front of the seat belt latches, or you can just reach under the passenger side and pull the cable like an old school bus stop cable. You might need someone to pull on the hatch at the same time depending on the adjustment of your hatch and bump stops.
Old Aug 6, 2016 | 12:42 PM
BUGETER's Avatar
BUGETER
No. Just lift up on the front of the rear seat. You should see a cable with a small ring on the end. Pull it and the hatch should pop. If you do not have someone to help, push on the rear glass to help the boot pop open.
Old Aug 6, 2016 | 12:45 PM
Drumsound's Avatar
Drumsound
Thanks, guys. I'm off to the garage.
Old Aug 6, 2016 | 01:04 PM
Drumsound's Avatar
Drumsound
So, I opened the passenger door, and the hatch lock started going nuts, as if it was cycling through all the times I pressed the key button. It seems to be working fine now. Either way, I'm glad to know I can reach under the seat if it happens again.
Old Aug 6, 2016 | 01:12 PM
Capt_bj's Avatar
Capt_bj
was it crying out for some lubrication?????
Not meant as a "cute comment"
shoot some silicon grease in there!
Old Aug 6, 2016 | 01:43 PM
Drumsound's Avatar
Drumsound
I'm sure that couldn't hurt. Thanks for the tip!
Old Aug 6, 2016 | 04:06 PM
Filmy's Avatar
Filmy
If it screws up again, the replacement latch part from Mini is surprisingly inexpensive - like $60 or so. Easy to replace.
Drumsound's Avatar
Drumsound
Good to know!!!
Old Aug 9, 2016 | 06:57 PM
DixonL2's Avatar
DixonL2
Do a search on the word "boonk", you may have moisture in your hatch switch. Easy fix, get a new part though since it's already dry!
Check these threads:
https://www.northamericanmotoring.co...h-problem.html
https://www.northamericanmotoring.co...h-me-help.html
Blueberry1980
Apr 11, 2016 09:40 PM
vixxysmini
Apr 5, 2016 06:42 PM
TrackToys
Electrical
Apr 2, 2016 01:22 PM
The duff king
Mar 22, 2016 06:23 AM
drstevenj
Oct 8, 2002 08:43 PM
