R50/53 Auto-Leveling headlights stopped working....help!
Old Aug 1, 2016 | 04:53 AM
IQRaceworks's Avatar
IQRaceworks
I hopped in the car this morning to head to work and when I turned the headlights on....instead of them pointing low when turned on and then popping up after a few seconds when the auto-leveling system kicks this...this time they both just stayed down.
I was under the assumption that each headlight has it's own leveling motor setup in it.......so why would both of them quit working? Is there a different fused circuit providing power for the leveling motors in each light? Maybe a fuse blew?
I'm going to dive in and start doing some trouble shooting after I get home from work today....just thought I might ask on here to see if anyone has had this issue before.......
Thanks for the help!
Old Aug 1, 2016 | 05:28 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Jack up car, see if the arm of the level sensor is hung up or broken. I have seen where one of the arms will sometimes rest/rub against the cable covering of E-Brake cable. The sensor is made of black plastic, with rivet hinge set up.
Some pics here: Auto Level Sensor
Old Aug 1, 2016 | 05:53 AM
IQRaceworks
Thanks for the info! There is on on the front left a-arm and also one on the rear left a-arm right?
Old Aug 1, 2016 | 06:23 PM
IQRaceworks
Ok...so I did a little more troubleshooting tonight. Both of the sensors along with their linkage looks ok. For years....when I have turned my headlights on....they are first pointed pretty low for a few seconds....then they will raise up to the proper level and "auto level" out.
Now.....when I turn the headlights on.....they start out really high, then drop down really low, then jump up three times...a little at a time until they are around the correct height. The motors in the lights sound kind of weird....something definitely is not right with them.
Could one of the sensors be bad? How can you test them to find out?
Any help would be great!
Old Aug 1, 2016 | 06:38 PM
RB-MINI's Avatar
RB-MINI
Do you still have pre FL xenons, or did you upgrade to FL projector xenon's?
Old Aug 1, 2016 | 07:01 PM
IQRaceworks
They are what ever came on the car back in 2003.
Old Aug 16, 2016 | 05:53 PM
Gecko.'s Avatar
Gecko.
Nothing to offer here, but I just wanted to get in on the discussion.
Mine have recently stopped working as well, but a little differently than yours. When I turn the headlights on they start out really low, and never jump up to the correct height.
Now, to drive to work early morning, I have to use the high beams full time, but they sit at a level lower than the normal low beam.
Old Aug 16, 2016 | 07:34 PM
RB-MINI's Avatar
RB-MINI
Gecko, what year is your MINI?
Old Aug 17, 2016 | 03:22 AM
Gecko.'s Avatar
Gecko.
BMW's maiden year, 2002.
Old Aug 19, 2016 | 01:59 PM
Check both the front and rear level sensors, also check the electrical connection at those plug points. See if the metal tabs are bent also. 37146784698 & 37146853759
https://www.northamericanmotoring.co...hen-right.html
https://www.northamericanmotoring.co...eml-light.html
If you get the schwaben tool you can see what light faults it can find:
https://www.northamericanmotoring.co...d-q-and-a.html
Then go the housing and see it the mount broke internal or the pivot ball joint of the fixture popped out.
Ygritte
Jan 22, 2019 06:48 PM
oreo1112
Aug 29, 2016 06:17 PM
Omatic
Mar 22, 2016 07:46 AM
Car Care Products
Mar 17, 2016 03:35 PM
wizardbill
27
Mar 29, 2005 09:41 PM
