R50/53 2003 R53- Need Hose Identification
Old May 16, 2016 | 03:57 PM
LANDSRAAD's Avatar
LANDSRAAD
Hi Everyone
I had a little bit of a mouse problem in my poor mini that sat idle for a while. Mr Mouse chewed threw countless things. I've handled most of it so far, but yesterday I noticed that the slight hissing I was hearing became MUCH louder. If only it was a mouse eating snake. Alas, it is the pictured hose here. However, I can't seem to locate it as a part. It's about 3.5" long x 3/4-1" in diameter. Clamped to the throttle body housing with a copper squeeze clamp. Plastic nozzle tipped pictured inserts into the hose. No clamp on that side.
CAN YOU HELP IDENTIFY THE HOSE, SO I CAN REPLACE IT? Mini of Manhattan doesn't have it on their parts diagrams.
Thanks again!
HOSE AND CLAMP I NEED - STOCK IMAGE
PULLED BACK TO SHOW WHERE IT ATTACHES TO THROTTLE BODY
ONLY PAY ATTENTION TO RED ARROW - STOCK IMAGE
ACTUAL PICTURE OF MY CHEWED HOSE WITH AIR TUBE FALLEN OUT - TUBE BLOWS COLD AIR
Old May 16, 2016 | 04:07 PM
HaltCatchFire's Avatar
HaltCatchFire
Appears to be the fuel tank breather line.
Old May 16, 2016 | 04:16 PM
LANDSRAAD's Avatar
LANDSRAAD
Thanks @HaltCatchFire. Any idea where I can just purchase the hose portion? If I have to replace the whole line, that is a much bigger project.
Old May 16, 2016 | 04:29 PM
xsmini's Avatar
xsmini
Just need that little short section, should be able to get at any parts store.
Old May 16, 2016 | 04:30 PM
HaltCatchFire
Looks like generic fuel hose to me, auto parts store would have it. Other might chime in if they know differently.
Old May 16, 2016 | 04:34 PM
LANDSRAAD's Avatar
LANDSRAAD
Wondering if it could be this...
Old May 16, 2016 | 04:41 PM
xsmini's Avatar
xsmini
No, just take off your chewed one and go into a auto store. They'll set you up with the correct tubing.
Nik
Old May 16, 2016 | 04:43 PM
LANDSRAAD's Avatar
LANDSRAAD
Thanks everyone.
Old May 17, 2016 | 05:22 AM
Yea , thats it, For the S is come in one for the manual tranmission :
13907515434
https://www.ecstuning.com/Search/SiteSearch/13907515434/
One version for the Automatics. 13907541090
https://www.ecstuning.com/Search/SiteSearch/13907541090/
Old Nov 2, 2021 | 09:38 PM
Aindrid's Avatar
Aindrid
Just to resurrect an old thread, anyone know where I might get the hose clamp for that fuel hose? mine appeared to have been replaced, but quite poorly and is rotting away. Trying to chase down a leak as well, but figured this would also be an easy replacement.
Old Nov 12, 2021 | 11:33 AM
Here you go for 13907541090
https://www.ecstuning.com/b-genuine-...h/16121180240/
The other line comes with the clip on it, not a separate part number
Old Nov 12, 2021 | 03:04 PM
Zillon's Avatar
Zillon
I just replaced that hose on my R53 as the original rubber hose was in poor condition.
It was easily done with 1/4" fuel line and a small screw-style hose clamp.
Old Nov 14, 2021 | 08:40 PM
Aindrid's Avatar
Aindrid
My understanding based on ECStuning's close-up of the full replacement part, is the Fuel Hose is 7.3 mm ID (inner diameter). 1/4" fuel line is the equivalent of 6.35 mm ID. I bought some, as opposed to spending ~$20 on 1 ft (or meter, i dont remember) for the proper stuff. Haven't gotten back to getting it all the way on, as I had no proper lube to assist me, its quite the tight fit. One of my racing buddies recommended just using some petroleum jelly. Plan on getting back to this in the next few days to further troubleshoot my leaking issue. Will probably try disconnecting individual hoses 1 at a time to see if the leaking noise goes away before buying any more new hoses.
quickcoop
Dec 4, 2020 09:05 AM
JimmyChooToo
Electrical
Jan 24, 2018 09:30 AM
Jimmy Devaney
30
May 27, 2016 11:00 AM
WildMini
Apr 8, 2016 07:23 AM
flyjets01
Mar 21, 2016 02:03 PM
