R56 R56 Serpetine Belt replacement
Old Mar 20, 2016 | 04:16 PM
miniuy's Avatar
miniuy
Hi,
I'm in the 100k KMS so i'm changing:
All air filters (engine/cabine)
Engine Serpentine Belt
Brake Fluid
Coolant
Spark Plugs (NGK every 50k)
Now I'm searching for the correct serpentine belt.
I was searching at RealOem with my VIN (T003915) but is not clear.
RealOem is saying something like "if you have something from Korea, then this your p/n if not there is your p/n)
Any one can help me with this?
I think buying it at WMW, ECS or Pelican Part could be the best way ...
Old Mar 21, 2016 | 08:13 AM
Hello,
I can help you , you have air conditioning, some MINI dont have it for some regions.
Then here: 11287604014
https://www.ecstuning.com/Search/SiteSearch/11287604014/
Looks at your old belt on the side should say maybe if its not worn off 6K X 895
Old Mar 21, 2016 | 07:04 PM
miniuy's Avatar
miniuy
Hello,
Thank you for your response!
I have "manual" air conditioning (not auto-climate).
Can I get the belt info without taking out the wheel and the fender? (to see the leyend 6K X 895)?
I will try it tomorrow from the engine.
Old Mar 22, 2016 | 07:41 AM
Welcome,
Thats it. Yes, look under the engine , near the belt ( passenger side ) and sometimes you can see the print on the outside of the belt. But thats it.
Old Mar 25, 2016 | 09:20 PM
miniuy's Avatar
miniuy
Welcome,
I could only see the print on the ouside of the belt:
02530333----------V760401480 01 6PK8
102530343-----------DAYCO----------------
It is enough info to select the correct belt?
Thank you!
Old Mar 28, 2016 | 07:24 AM
MiniToBe's Avatar
MiniToBe
call the dealer and ask them for the part number. they should be able to give it you over the phone. then buy it online
Old Mar 28, 2016 | 07:37 AM
Thank you!
Thats it linked above: Genuine MINI 11287604014
Old Mar 31, 2016 | 01:17 PM
miniuy's Avatar
miniuy
Yes it is! I'm ready for the order on ECS site in the next days.
Thank you for your help !
Old Mar 31, 2016 | 01:41 PM
Welcome.
And thanks for the support.
Old Apr 15, 2016 | 08:05 AM
miniuy's Avatar
miniuy
Welcome.
Thank you !
Old Apr 15, 2016 | 08:11 AM
1004ron's Avatar
1004ron
All the belts that @ECSTuning has listed are good, but my personal preference is the Gates (Made in the USA).
https://www.ecstuning.com/Search/Sit...014/ES2975764/
Old Apr 15, 2016 | 10:41 AM
miniuy's Avatar
miniuy
Yes, I was reading a lot before buying the belt and I could see that Gates is the #1 in quality.
I ordered the OEM one just because it looks identical.
Old Apr 15, 2016 | 11:14 AM
1004ron's Avatar
1004ron
I'd have peace of mind with any of the ones @ECSTuning has listed, after-all, it sounds like you have a 100k on the OEM belt.
Old Apr 19, 2016 | 05:33 AM
Thanks for the support.
Old Apr 19, 2016 | 06:55 AM
miniuy's Avatar
miniuy
I'd have peace of mind with any of the ones has listed, after-all, it sounds like you have a 100k on the OEM belt.
Yes, I'm just over 100k km on the OEM belt.
Just changing it as part of preventive maintenance.
Thanks for the help !
Old Apr 19, 2016 | 07:01 AM
Welcome.
Shen456
Jun 15, 2021 03:51 PM
Saovalle
Tires, Wheels, & Brakes
20
Mar 9, 2016 04:18 PM
WayMotorWorks
Mar 3, 2016 09:33 AM
SneedSpeed
Feb 29, 2016 12:01 PM
Kr4nG
Feb 22, 2016 06:00 AM
