Suspension suspension install in sf bay area cost?
Old Mar 16, 2016 | 01:47 PM
nels415's Avatar
nels415
Hi folks,
I just ordered some Koni fsds, a rear sway and front control arm brackets. Any idea how many hours of labor I should be looking at, approximate cost for shops in SF Bay area?
-nels
Old Mar 16, 2016 | 01:54 PM
goin2drt's Avatar
goin2drt
Originally Posted by nels415
Hi folks,
-nels
5 hrs is a safe bet. Not sure the labor cost in your area. I just had KW's installed and it was a little over an hour a corner.
Good luck and cheers.
Old Mar 16, 2016 | 02:13 PM
nels415's Avatar
nels415
Thanks goin2rt. How many hours would you estimate for just the strut install? I may do the rest myself to save a few bucks. Oh nevermind, you mentioned about an hour each corner, so you're estimating about 4 hours. thanks.
-nels
Old Mar 16, 2016 | 02:27 PM
goin2drt's Avatar
goin2drt
Correct. My coilovers were about 1:15 per corner. I beleive to do the sway bar it could be more as the sub frame needs to be dropped to access that I beleive.
Old Mar 16, 2016 | 03:27 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
For the rear sway bar, our article states it should take the average DIY'er 1.5 hours. We have a pretty good guide to help you do it if you want to tackle that job by yourself. Also, I'd call around and get a few quotes. Each shop will be a little different. This is a good site to help you find a few in your area if needed: http://www.minirepairshops.com/
888.280.7799 | 6am - 5pm PST
Old Mar 16, 2016 | 05:57 PM
RB-MINI's Avatar
RB-MINI
Not sure about their rates, but some MINI shops in the Bay Area are Bay Bridge Motors in Oakland, MINI Werks in San Carlos, and Edge Motorworks in Mountain View or Dublin.
Old Mar 16, 2016 | 06:46 PM
nels415's Avatar
nels415
Thanks for the shop suggestions RB-MINI!
Old Mar 17, 2016 | 01:52 PM
There are plenty of MINI out in SF, labor rates in SF are higher then most , so shop around. I know the dealership out there has some of the highest rates in the country for MINI.
Old Mar 17, 2016 | 04:03 PM
nels415's Avatar
nels415
Is it correct that you have to drop the subframe for installing both the rear swaybar and front control arm brackets?
Old Mar 17, 2016 | 04:12 PM
RB-MINI's Avatar
RB-MINI
The front control arm bushings can be done both ways depending on if you are doing bushings only, or if you want/need to remove the entire bracket. I think you can do the rear sway bar by partially lowering the rear subframe. There are Youtube videos for both installs.
Old Mar 17, 2016 | 05:20 PM
nels415's Avatar
nels415
I bought the brackets because I didn't want to deal with just the bushings. Thanks for responses RB-MINI.
Old Mar 17, 2016 | 05:56 PM
RB-MINI's Avatar
RB-MINI
Might want to check the power steering hoses while the subframe is dropped, too. They're know to leak on 1st gens so it would be pretty much the cost of the parts at that point. Not sure if this was still the case on 2nd gens... maybe ECS or Pelican can answer.
Old Mar 17, 2016 | 10:14 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Gen2s have electric power steering so no PS hoses.
I think 1hr/corner should be generous for an experienced shop. RSB should be less than 1/2 hr incremental time since the car is already in the air with the wheels off and shocks out. Yes you have to lower the rear subframe but it is only a few bolts.
I DIY'd my RSB in about 1.5 hours, and separately DIY'd coilovers all around plus rear control arms in about 8 hours, in the garage with just jackstands, no lift and no air tools. I could do it again in much less time.
Old Mar 18, 2016 | 07:39 AM
PelicanParts.com
Vendor
For the rear sway bar, you just have to lower the subframe about three inches. Here's what it looks like from our DIY. Check it out as it has some great detail and images that can give you an idea of what the job looks like.
Old Mar 18, 2016 | 07:47 AM
Originally Posted by RB-MINI
Might want to check the power steering hoses while the subframe is dropped, too. They're know to leak on 1st gens so it would be pretty much the cost of the parts at that point. Not sure if this was still the case on 2nd gens... maybe ECS can answer.
For Gen 1:
I did my front suspension :
https://www.northamericanmotoring.co...ll-joints.html
and the power steering lines at the same time:
https://www.northamericanmotoring.co...hose-pics.html
Much easier to do the lines while you are there.
But.. for Gen 2 You dont have power steering lines, its electric Power steering enclosed unit in the power steering rack.
The suspension parts you check on the front for Gen 2: R56+
https://www.northamericanmotoring.co...placement.html
wearlaz
May 8, 2016 03:30 AM
cakeater
Mar 17, 2016 12:18 PM
03cooperr53
Suspension
Mar 17, 2016 01:01 AM
RocketUSA
14
Mar 16, 2016 10:38 AM
danraabe
Mar 15, 2016 03:27 PM
