R50/53 Finding Nemo
Old Mar 2, 2016 | 01:31 PM
redlinedave's Avatar
redlinedave
Finding Nemo
Hi all
I have been charged with finding a Mini for a friend, The first gen looks best to me and prices are fair.
There are several for sale with kms from 100,000 to 220,000kms on clock.
The car must be a stick, this gal hates auto, sunroof a must.
At what km are major services needed? Timing belt? I dont want to find a car only to find out it needs a major service.
Are there any common problems and when where do they show up? IE Toyota Tundras have a problem in the heater box that is a $1200 fix.
Anything like this to keep an eye out for?
Any weak spots to look for?
Would you stay away from a modded car? to me it says driven hard or possibly tracked?
I can do my own oil,brakes and smaller jobs but I dont have a hoist so new brakes wont sway me on a car, I just need a little help on what to look for.
Old Mar 2, 2016 | 02:19 PM
Timing chains, and they dont have a history of going bad.
At 100,000 I would do suspension
https://www.northamericanmotoring.co...ll-joints.html
and power steering lines.
https://www.northamericanmotoring.co...hose-pics.html
Belts and normal wear items should all be done. I would get the car first or find one, see it in person get a PPI inspection , have it up on the rack and make a list.
Major things are Power steering pumps / fan, but should be under MINI canada warrenty.
https://www.northamericanmotoring.co...ring-pump.html
Rust for MINI up north.
2005+ have the longer warranty>
https://www.northamericanmotoring.co...oper-rust.html
Superchargers needing rebuilt. they can last past 100,000 miles , and can be serviced as far as gear oil changes.
https://www.northamericanmotoring.co...on-02-mcs.html
All the others are minor. But with higher miles the clutch / flywheel might need replaced. Most go with the dual mass to single mass conversion from Valeo.
https://www.northamericanmotoring.co...utch-disc.html
Old Mar 2, 2016 | 02:43 PM
redlinedave
I found this
http://www.britishamericanauto.com/c...er-Owners-Face
Old Mar 2, 2016 | 02:46 PM
Those articles like to mix up models and chassis. One posted above are for the R53 / R52 Cooper S, and to some extent the R50 and R52 Cooper. Since that's what you were looking at Gen 1 MINIs.
Old Mar 2, 2016 | 03:48 PM
redlinedave
found this
Old Mar 2, 2016 | 03:54 PM
jgk6502's Avatar
jgk6502
Dave. That's the one. ModMini has everything you need to start.
Old Mar 3, 2016 | 05:27 AM
Good video.
Old Mar 3, 2016 | 09:21 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Don't forget to check out the R53 buyer's guide by MotoringFile HERE. I'd also check out the power steering pump. Check the fan too to make sure it's operating properly. The power steering pump on the MINI is one of those items that seems to have a bad reputation. I'd also check the strut tops for mushrooming as well.
888.280.7799 | 6am - 5pm PST
Old Mar 3, 2016 | 12:13 PM
redlinedave
All good advice, I did see a fix for the shock towers.
Do these work?
Old Mar 3, 2016 | 12:16 PM
PelicanParts.com
Vendor
Yep! We have a few options here: http://www.pelicanparts.com/catalog/...pg5.htm#item28 Let me know if you have any questions about either of them.
Old Mar 3, 2016 | 12:19 PM
Those are the under-strut towers , another type fix that goes underneath, Our ECS goes on top.
https://www.northamericanmotoring.co...shrooming.html
Old Mar 3, 2016 | 12:26 PM
redlinedave
Cool, I will start to look at cars next week, I've found a few. there is about 75 cars that meet my search needs within a couple of hours driving time. Too cold to look at cars right now -10 C and I'm in no great rush. Just using the time to educate myself more on these cars and current prices
Old Mar 3, 2016 | 12:28 PM
Welcome, when you have time to search you can find gems ! Good luck.
wilkrod
Mar 20, 2016 07:54 PM
cdavidell
Jan 20, 2016 01:50 PM
Jan 19, 2016 11:38 AM
Jan 18, 2016 10:38 AM
Jan 15, 2016 03:56 PM
