R52 05 r52 power steering fan fuse help needed!
Old Feb 22, 2016 | 02:33 PM
bijou93's Avatar
bijou93
My power steering pump and fan need to be replaced. While I wait for parts I would like to be able to pull the fuse that runs the power steering fan because it's not shutting down and is draining the battery.
I'm now cold and wet, tired of trying every single fuse and can't find a decent list of what fuse runs what online. If anyone could help me here I would be immensely grateful!
Tamra
Old Feb 22, 2016 | 03:47 PM
RB-MINI's Avatar
RB-MINI
I don't think there's a fuse that can be easily pulled, if at all. I would also worry more about the car catching fire than the battery going dead, especially if parked indoors... seriously.
As much of a pain as it is, I added a battery quick disconnect switch because I had to store my car in at a relatives house occasionally. I wasn't having power steering pump issues, but just felt it would be safer since it wasn't my house that would possibly burn down if the pump stuck on one day.
It's an issue that's has happened many times, just search this and other forums for stories.
Old Feb 22, 2016 | 06:18 PM
ZippyNH's Avatar
ZippyNH
If the PS PUMP is staying on, You will need to disconnect the battery....no simple way to yank a fuse/relay...it is buried on the UNDERSIDE of the fuse block with the fuses under the hood...the fuse # for the PS FAN varies depending on the production date, and if the fuse was factory, or dealer rewired like on many 2005 year cars....
Yes...no simple an answer... The pump is very hi amp....so it does not have wires or fuses that are easily accessible.. Mostly for safety I bet.
Old Feb 23, 2016 | 06:30 AM
Fuse locations :
https://www.northamericanmotoring.co...ml#post2163709
https://www.northamericanmotoring.co...-loaction.html
What month ./ year production are you , if you are under the service bulletin, you can get it replaced by MINI. I would get that checked out asap.
service bulletin : https://www.northamericanmotoring.co...50k-miles.html
Rock944t
Apr 4, 2020 10:22 AM
Rich Rodichok
R60/R61 Stock Problems/Issues
19
Nov 27, 2017 06:48 AM
jpinkerton
Feb 19, 2016 04:41 AM
Austinsynthetics
Feb 17, 2016 11:09 PM
sam355
Feb 17, 2016 09:52 AM
