Does anyone have the template for the JCW BBK to determine what wheels will fit?
Old Feb 22, 2016 | 12:44 PM
Pertplus's Avatar
Pertplus
Trying to find the info so I can send it to my wheel manufacturer to see if the BBK will fit with my current wheels. I know there are posts about what wheels wont fit, but is there the actual data with a template of of the JCW kit so manufacturers of wheels can determine what will and wont fit? Thanks.
Old Feb 25, 2016 | 11:34 AM
NM engineering has MINI wheels that will fit otherwise you will run a 15mm spacer on the front.
https://www.northamericanmotoring.co...wheels-10.html
MINI wheels with 15mm spacers :
Gen 3 F56 / F55 5-20mm
https://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Wheels/Spacers/
There is also one MINI wheel that will fit : 36116855102 506 JCW BBK wheel 18"
https://www.ecstuning.com/Search/SiteSearch/36116855102/
Old Feb 25, 2016 | 11:35 AM
Pertplus's Avatar
Pertplus
NM engineering has MINI wheels that will fit otherwise you will run a 15mm spacer on the front. https://www.northamericanmotoring.co...wheels-10.html MINI wheels with 15mm spacers : Gen 3 F56 / F55 5-20mm https://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Wheels/Spacers/ There is also one MINI wheel that will fit : 36116855102 506 JCW BBK wheel 18" https://www.ecstuning.com/Search/SiteSearch/36116855102/
I already have Volk G25s so not swapping those out. I'm all good, going with a Brembo BBK.
Old Feb 25, 2016 | 11:47 AM
Ok,if you already have the wheels in mind. In that link about wheel, you will see what has fit and offset. Every wheel is different because of the way the inside barrel and face of the wheel contours. Might have to get your JCW BBK , mock up on one wheel and measure out. Just rough fit the BBK on one side, then you just unbolt the rotor and caliper stock , pull it back to the side , watch that brake line .
Old Feb 25, 2016 | 11:48 AM
Pertplus's Avatar
Pertplus
Thanks!
Old Feb 25, 2016 | 11:56 AM
Welcome, thats how most of its done for fitment.
Old Feb 25, 2016 | 11:57 AM
Pertplus's Avatar
Pertplus
I'm actually meeting with Race Technologies next week.
Old Mar 9, 2016 | 09:14 PM
hanzov69's Avatar
hanzov69
I don't want to hijack, and since it seems relevant and I want to be sure:
I have a 2016 F56 with NM Eng RSe12's now. If I want to go to the BBK, I would want this, right?:
https://www.ecstuning.com/Mini-2015-...20A/ES2925411/
And then add the 15mm wheel spacer kit, here:
https://www.ecstuning.com/Mini-2014-...ers/ES3006111/
Right?
andersonspedini
Nov 6, 2018 12:39 PM
311mini
R55 :: Clubman Talk (2008+)
Feb 18, 2016 12:46 PM
J Free
Jan 28, 2016 09:21 AM
Eugene Arnold
R58 :: Coupé Talk (2012+)
Jan 26, 2016 10:13 PM
