HELP: Where to buy oem parts?
Old Jan 22, 2016 | 07:48 PM
R5609's Avatar
R5609
I'm new to the mini scene and just found out my car is heating/losing coolant, I need;
Water pump
Water pump housing
Thermostat
Where is the best place to buy great parts at a low price? How much should it cost me? Anything else I should replace at this point? 2009 MCS 97k miles.
Old Jan 23, 2016 | 06:32 AM
gjxj's Avatar
gjxj
if you do both thermostat and pump, also replace the pipe between them. The pump and thermostat are essentially seperate jobs by the way, you really ought to take the time to find the leak instead of just replacing everything.
Old Jan 23, 2016 | 07:57 AM
Fly'n Brick's Avatar
Fly'n Brick
+1
There are several vendors on this forum each carrying various items. Visit their websites. Any number would be pleased to help you if you make contact with them.
Old Jan 23, 2016 | 08:00 AM
Fly'n Brick
It's interesting that at this posting, there are 396 views shown to be made on this particular thread and only two responses. Hmmmm.
Old Jan 24, 2016 | 07:49 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We keep all that in stock,
R56 thermostat
http://www.waymotorworks.com/thermos...5-r56-r57.html
New OEM aluminum water pump, you prob have old plastic one and that is why it is leaking
http://www.waymotorworks.com/water-p...8-r59-r60.html
And water pump pipe
http://www.waymotorworks.com/water-p...9-r60-r61.html
Can ship it all tomorrow, we combine shipping on orders to ship as cheap as possible for you.
Old Jan 25, 2016 | 08:32 AM
Water pump
Water pump housing
Thermostat
We have everything to look for here with a DIY linked. I have done this before, s o if you need help you can always PM me,.
https://www.northamericanmotoring.co...8-no-heat.html
Old Jan 25, 2016 | 10:39 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Water pump
Water pump housing
Thermostat
We have water pump super kits HERE that includes all that you need, plus some good additional options to replace while you're in there. Otherwise, the water pump and thermostat/housing is below at that same link. We also have DIY's at our site under MINI > Tech Info Tab (at top) > R56.
888.280.7799 | 6am - 5pm PST
Old Jan 26, 2016 | 10:28 PM
R5609's Avatar
R5609
You guys are amazing! I will be ordering the parts Friday. Thank you for making it easy. Now to find a place to install everything in Portland.
Old Jan 27, 2016 | 04:59 AM
You are welcome. Indy shops can be found with a quick google search in your area, try BMW shops as some do MINI also.
Or https://www.automd.com/shops/
http://www.autoblog.com/auto-repair-shops/
Old Jan 27, 2016 | 06:47 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
tel://5036430105 sebastian autobahn motorwerks does good work.
Old Jan 27, 2016 | 08:47 AM
PelicanParts.com
Vendor
Try this site HERE.
Old Jan 28, 2016 | 11:43 AM
sevin's Avatar
sevin
You can get OEM parts from ECSTuning, PelicanParts, and WayMotorWorks. All great vendors. They also all regularly post here, as you've already seen. Another great resource to BMW and MINI owners is realoem.com. You just punch in the last 7 characters of your VIN and you can browse exploded diagrams of every single system in your car, complete with part numbers, supplier pricing, and the dates through which each part was used in production. They even have listings of retrofit kits for stuff your car may not have been optioned with. Really great resource that most other car manufacturers do not have.
Old Jan 28, 2016 | 12:15 PM
Thanks for the support. Realoem.com is a great tool when you look for the 11 digit part number. You can also use our ECSTuning site. Realoem.com has most of the catalog, but not all, some part number don't show up like ( 11614584240 ) . If you looking for hard to find parts or strange off ETK parts you can always PM me. I usually can find them or a source that has them.
Old Feb 29, 2016 | 11:49 PM
r7denz's Avatar
r7denz
You can also go to realoem.com to find the correct Part Number. This makes searching online easier for the parts/accessories you need.
Old Jul 3, 2016 | 12:29 PM
R5609's Avatar
R5609
anyone have coupon codes or doing a 4th of july sale
Old Jul 3, 2016 | 02:35 PM
Mini Mania's Avatar
OEM and Value Line OEM parts available here http://new.minimania.com/index.cfm
Old Jul 21, 2016 | 08:43 AM
mustman's Avatar
mustman
I don't know what part of the country you're in, but I've always used http://parts.seattlemini.com/ when it had to be an OE part. They're a little bit cheaper than most places but the shipping is usually a lot cheaper.
Longitudinal
Dec 4, 2015 10:16 PM
JPMontes3
Dec 3, 2015 10:05 AM
ti22fjc
Nov 30, 2015 03:55 PM
anitan1
Nov 26, 2015 10:10 AM
schr5530
Tires, Wheels, & Brakes
Nov 24, 2015 07:24 PM
