R50/53 Powerflex LCA bushing not fitting?
Old Jan 22, 2016 | 11:34 AM
takrdown's Avatar
takrdown
Hey guys and gals! I received the Front Lower Control Arm Rear bushing from powerflex a couple of weeks ago from you and finally had the opportunity to install it today. I'm lucky enough to work at a submarine refit facility so I have access to a 50 ton hydraulic press.
I removed the entire mounting bracket and brought it to work with me and attempted to install the bushings. Needless to say there was nothing I could do to get them to fit. I would start applying pressure and the bushings would never enter the bracket evenly. Eventually the entry lip would catch around 1.5 tons of force and the entire machine would shake. The chamfer of the bushing will not fit into the bracket.
I decided it best to stop. I've checked that I'm installing everything in the correct manner three different times and that the part number on the bushing was correct. Is there a chance that the bushing that goes into bracket is too large or there was a factory error? I measures the ID of the bracket and the OD of the bushing and the bushing is greater than .002 larger which is way more than just an interference fit.
Can anyone provide some assistance? Thanks!
Old Jan 22, 2016 | 11:43 AM
nkfry's Avatar
nkfry
They are just a tight fit, for someone who hasn't done them before you may think something is wrong, but that is how they fit.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 22, 2016 | 11:51 AM
takrdown's Avatar
takrdown
So a 50 ton industrial press should be made to shake? I feel like I'm going to tear the bushing. There is just no way to get them to go in evenly.
Old Jan 22, 2016 | 11:54 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We do have a control arm bushing replacement DIY here that might be helpful.
This is from our DIY, image #13 at that article.
Getting the new bushings/brackets started on the control arms can be a bit of a challenge. BMW specifies the use of a specialized press tool, but I found that using a little silicone lubricant on the inside of the bushing along with a quick good blow with a hammer managed to get the bushing on enough to where I could push it down all the way.
You have to get it started just right. Freezing the bushing before you try to install it might help as it helps contract the rubber of the bushing. Once you start pressing it the amount of heat getting it to press in is pretty substantial. Hope some of this helps. Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
Old Jan 22, 2016 | 12:04 PM
nkfry's Avatar
nkfry
We use a 20 ton press to install them, we install on average 2-3 sets a month.
A little lubrication helps, but you need to be conservative, as too much will actually coax the bushing to pop out of the bracket instead of into it.
As I said, it is a very tight fit and may worry some who haven't done the job before.
If you don't want to risk it you can send the brackets and bushings to us and we will press them in for you. We charge $20 to press bushings in.
Phone:586-792-6464
Old Jan 22, 2016 | 12:05 PM
Did you maybe put a gen 2 PF bushing in a gen 1 ?
https://www.northamericanmotoring.co...gen2-mini.html
Old Jan 22, 2016 | 12:15 PM
takrdown's Avatar
takrdown
They are black so they appear to be the Gen 1.
Old Jan 22, 2016 | 12:16 PM
takrdown's Avatar
takrdown
Thanks I'll have to keep it in mind. Do you have any tricks to make the bushing not want to lean over to one side or if it does lean over should I just keep going?
Old Jan 22, 2016 | 12:19 PM
nkfry's Avatar
nkfry
It requires some finesse. You need to hold the bushing and bracket from the back while applying press force, basically counter the direction it wants to lean to. Once you get it to a certain point it will just "pop" in, then bottom it out and you're done.
Phone:586-792-6464
Old Jan 22, 2016 | 12:30 PM
Just making sure, yes they fit tight and sometimes its a battle. Working it is the key. And glad you have that press. Would love to see that 50 ton press in action. Have you seen the locomotive hoist , thats awesome.
Old Jan 22, 2016 | 02:20 PM
Shawnnn's Avatar
Shawnnn
Mine kept going in kind of crooked so finally I just said screw it, and kept pushing. They eventually straitened out and went in fine.
Old Jan 22, 2016 | 02:59 PM
takrdown's Avatar
takrdown
I feel like an idiot!!!
So I used the reciprocating saw method to remove the old, OEM, ones. What I failed to realize was that the metal sleeve that stayed behind after I did that was not part of the bracket but was in fact part of the old bushing. That explains why I had so much damn trouble. I feel like an idiot!
After I sawed out the metal piece the bushing went in like a glove....almost too easy
Thanks guys!
Old Jan 22, 2016 | 03:08 PM
Shawnnn's Avatar
Shawnnn
Lol, glad you figured it out
We've all been there!
Old Jan 22, 2016 | 09:39 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It wouldn't matter they fit the same. We use the Gen 1 in all the time as I prefer the black outers for durability.
Old Jan 24, 2016 | 06:43 AM
daviday's Avatar
daviday
Happy you figured it out. You're going to love them.
Old Jan 25, 2016 | 05:02 AM
Thanks guys!
Glad you have it fixed , yea that stuck metal sleeve from the old one will hold you back.
Kahnfucious
20
Dec 30, 2019 05:34 AM
Rennfahrer555
Houston MINI Motoring Society
26
Oct 13, 2016 04:56 PM
polepino
Dec 4, 2015 09:30 AM
Jb16
Nov 28, 2015 09:33 AM
Brandon Leonard
Nov 23, 2015 12:25 PM
