JCW Guys (Rye) I need help pls
Old Nov 27, 2015 | 04:23 PM
Jb16's Avatar
Jb16
Tried to install my NM lowering springs but I'm stuck. I can't seem to push the control arm low enough to get the strut out. Everything that needs to be removed have been taken out; sway bar link, tie rod, ball joint, wheel housing bolt, strut tower bolts. Any tips or tutorial? Thanks.
Old Nov 28, 2015 | 09:33 AM
Ryephile's Avatar
Ryephile
Put the strut top bolts very loosely back in to keep the strut as high as possible. Next, have a big heavy friend stomp on the brake rotor to push the control arm lower. The newer the car, the more force required to lower the control arm enough to release the strut. If you're a slim guy like me, you might not have enough weight to do it safely.
..and remember, this is just one reason why bolt-on struts are better.
InDaClubMan
Nov 14, 2015 02:53 AM
M7Speed
Suspension
Nov 10, 2015 07:44 AM
M7Speed
R61 :: Paceman Talk
Nov 10, 2015 07:42 AM
Grey Lightning
Nov 9, 2015 08:43 AM
burble_durble
11
Nov 2, 2015 07:34 PM
